Removed user as requested
10-02-2010, 10:05 PM
How much does the rear window tunnel effect, of the charger affect top speed?
Comparing the 68 charger to say a 68 Bee which has not got the sail panels going past the rear window... which would be better at top speed between the 2?
Also, racing on a circuit, do you ever exceed 300km/h or not and thus the rear window issue is not even an issue because on a circuit you never reach the speed when it would have impact and thus the rear window issue is not an issue and only becomes an issue on Nascar style tracks where you can go flat out because there is no corners?
Lastly
Converting a 68 charger rear into a charger 500 rear (without the daytona wing), would that cost more than say, getting a charger 500 to start with and modifying the grill so its like the 68 charger grill... or does this work out about the same.
Lastly
