View Full Version : 1" bore master
Railing68
05-21-2005, 06:30 PM
I have searched around and not found anything concrete as far as an application for use with ls1 fronts and 93-7 4th gen rears. After some research at the local autoparts place, I bought master cyl for 75 caprice. It is power and has 1" bore. Since the same is true of the 98-02 camaro shouldn't this work for the fronts? The rear is fine since the bore of the caliper is close to the wheel cyl according to BAER. I think it should work. Any thoughts? SS
