View Full Version : u-joints and driveshaft problems: im under the car now
dusterbd13
09-19-2010, 07:14 AM
im working on my 70 duster today. found a rear u-joint that had a LOT of play in it. it was rocking a bit in the yoke on the rear axle. put the correct u-joint in it, and the caps are turning inside the holes on the driveshaft. if i rememebr right, they arent supposed to do that. Am i correct? is there any simple fix?
Michael
taz
09-19-2010, 07:22 AM
If so some ujoints use different size caps for yoke and drive shaft . or you got wrong ujoint . It should be a press fit .
taz
09-19-2010, 07:40 AM
http://www.stocktonwheel.com/about_us.htm We used them years ago they widen and install the center in wheel size within reason . Love the mopars relocate the springs inboard and a 12 inch wide tire goes right in .
Tim
thedodgeboys
09-19-2010, 05:24 PM
Michael
you have the wrong u joint :(
your drive shaft uses the large u joint and your rear end is the small ujoint.
you need a COMBINATION U JOINT TO CONNECT A 7260 MOPAR STYLE DRIVESHAFT YOKE TO A SPICER DANA 1330 STYLE If it's 1 1/16", then it's a 1330, but if it's 1 1/8" then it's a 7290.
I think these are the right part numbers :)
TRW part #20226 or
CR UJ347,
Mancini 5-527X
Auto zone 2-0527
Napa NUJ240-0369
Neapco 2-0527
