View Full Version : good day then kinda went bad
speedshftr
09-18-2010, 07:08 AM
got the camaro started today after almost 3 years.
when i had the engine out a while back it fell off the engine stand cause i didnt have strong enough grade bolts on chain.never did find them in shop/lol
well after the car was running we noticed the harmonic balancer and water pump pullyes were really wobbleing.after a quick check indeed the water pump shaft and harmonic balancer were slightly bent so to speak. one step forward 2 steps back.i have to say though she sounded real good while it was running.ill be searching the summit book tonight i guess and begging the wife for a few parts.i also need the 2 groove pulley for the balancer.just had to share my day with you guys.thanks for listening.
Martin71RS
09-18-2010, 07:27 AM
bummer..... I hope it's just the balancer, not the crank....
good luck!
Martin
mc84_zz4
09-18-2010, 10:23 AM
you can use some chalk to determine what part of the balancer is pushed out more, and if it is a 2 piece pressed balancer (stock style) with the rubber/urethane ring, you can smack it back to level with a piece of wood and hammer (assuming it got pushed in, smack it from the back).
Not sure on the other higher-end fluid filled....
HTH
speedshftr
09-18-2010, 10:50 AM
engine fell about 1 foot to the ground.im praying its not the crank.thanks for the replies guys.:cheers:
