pitts64
09-17-2010, 04:26 AM
I'm thinking about switching to the new Scarebird disc brake set up. Both use the GM D-52 Caliper. This how they compare.. Do you guys think it would be worth it? The difference is around $300...
The new set up uses this 77 Bonneville Wagon Brake Rotor;
Diameter : 11.86"
Brake Rotor Discard Thickness : .97"
Brake Rotor Thickness New : 1.04"
Brake Rotor Type : Disc Brake Rotor & Hub
Height : 4.65"
The old set up I have now uses this 77 Seville rear Hat Rotor on the stock front hub;
Brake Rotor Diameter : 11.16"
Brake Rotor Discard Thickness : .91"
Brake Rotor Thickness New : .98"
Height : 2.2"
Thank you...
Diameter : 11.86"
Height : 4.65"
Height : 2.2"
Thank you...
