View Full Version : Creating a Custom Paint Mix
wellis77
09-17-2010, 12:00 AM
So how does one go about creating a custom mix? I had a rendering done and the blue used in the rendering is not an off-the-shelf color. I have a photoshop swatch of the color, now what? Can I use the digital swatch to get a custom color mixed or...?
elitecustombody
09-17-2010, 03:59 AM
nope, you'd have either use color swatches at the paint shop/store and tweak the color or eyeball and mix the color yourself with toners from mixing system till you come up with desired results
Happyfunballs
09-17-2010, 04:13 AM
Yep, and if you intend to do that, better write down the mix. A fatal error I've made more than once in the past.
nkopper
09-17-2010, 05:59 AM
And make sure you buy enough for touch ups later on. I had a custom green mixed for my motorcycle and a few years later, needed more for some aftermarket body parts. Went back to the same paint store and had it mixed with the same formula, but it didn't quite match.
