View Full Version : Complete G-Body DSE suspension upgrade
xxxturbo6
09-13-2010, 08:05 AM
I would like to start this off with a little information on what we’re doing to our GNS Test Car and our goals then move into the build process with some install pictures. Our goal with this car is to frequent Autocross & Road courses while keeping a Track Ready Street Friendly handling car whether it be on the street, at the drag strip or on a closed course. Our motto here is "Function is Everything"!
We chose Detroit Speed & Engineering’s full G-Body suspension package as the suspension for our GNS Test car. We will be at DSE Tomorrow documenting and doing the install. One thing about DSE, They are pounding their cars every weekend, customers are pounding their cars every weekend, and most of the time a DSE equipped car is winning (Frank Serifine) and that alone made it an easy choice for us.
We will start off with some basic measurements to give us a base to start with.
Here are a few basic numbers on our GNS test car:
Wheel base: 2746mm - 108.1in
Track: Front: 1486mm - 58.5in / Rear: 1466mm - 57.7in
Length: 5095mm - 200.6in
Width: 1819mm - 71.6in
Height: 1387mm - 54.6in
Drag Coefficient: 0.410 (Tested by GM)
Current Tire / Wheel sizes: Wheel make- CCW / 3-Piece
FRONT WHEEL: 18" X 9.5" - 4.75 Back Spacing
REAR WHEEL: 18" X 10.0" - 4.75 Back Spacing
FRONT TIRE: 255-35/18
REAR TIRE: 285-40/18
NOTE: No rubbing issues at all with stock suspension!! Went to Hotchkis lowering springs in the rear only and it dropped it perfectly 1". Got minor rubbing so I rolled the lips with the moldings.
A lot more info on wheels & fitment here:18" CCW Wheels on Scot W's car.. (http://www.turbobuick.com/forums/brakes-suspensions-tires-wheels/295464-18-ccw-wheels-scot-ws-car.html)
Stock ride height from floor to wheel well lip w/CCW wheels:
FRONT: 25.5"
REAR: 27.75"
REAR ride height After installing the Hotchkis lowering springs = 26.75"
4-Corner Scaling: Done on (8/30/10)
Next we SCALED the car on all 4 corners to give us a weight on all 4 corners before installing the DSE suspension. After the installation we will re-scale the car to see how much weight was shaved and where.
When trying to even up cross weight you want to get as close to 50% as possible.
Here is what we had in the car had at Scaling..
* Full tank of gas just topped off!
* Nothing left inside the cars counsel /glove box, no floor mats.
* Nothing in the trunk.
* Tires at recommended pressure.
First we started with leveling the scales on the surface to make sure they were level before we started. This was done using a 6ft level across the scales, and then we jacked the car up in the center and lowered it onto the scales front & rear. With the whole car resting on all four individual scales we took measurements.
FRONT "CAR ONLY" :
* Left = 997 lbs
............................Total front "car only" = 1,953 lbs
* Right= 956 lbs
REAR "CAR ONLY"
* Left = 695 lbs
............................ Total Rear "car only" = 1,436 lbs
* Right = 741 lbs
Completed Percentages & Formula:
Front Bias: 1953 / 3389 = .57627 = 57.6%
Rear Bias: 1436 / 3389 = .42372 = 42.4%
The left front and right rear are heavier than they should be. The left side usually is heavier than the right, - "without driver". Next time we scale the car we will disconnect one end link on the front and rear anti roll bars when scaling, then connect them on the scales and shim them so they don't jack weight from one corner to the other. Doing this removes any unwanted bind the sway bars could be causing. Raising a spring perch on the LF corner will increase weight on the LF and RR corners.
Our left and right side weights add up to almost even, so by adjusting the heavy corners we should be able to balance them pretty close without driver.
Next post will be install pictures and more measurements.
SW.
Picture below is how the car sits now... Stay Tuned! More to Come!!!
https://static1.pt-content.com/images/pt/2010/04/misc008-1.jpg
John Wright
09-13-2010, 08:39 AM
Nice looking car...stance looks good as is... the new performance add-ons should enhance your driving experience. Even if you don't lose alot of weight the car should work better...so that would be a plus that may or maynot show up on the scales.
xxxturbo6
09-13-2010, 09:00 AM
Nice looking car...stance looks good as is... the new performance add-ons should enhance your driving experience. Even if you don't lose alot of weight the car should work better...so that would be a plus that may or maynot show up on the scales. Thanks John! Both DSE and I want to keep my ride height the same if all possible. I figured I might shed some weight on the front A arms by getting rid of those heavy/bulky stock ones. There is no doubt it will be a much better and enjoyable ride and there won't be a worry when heading onto a closed course to thrash on it!! :)
Were just trying to cover all bases by measuring and weighing everything before/after each step for future reference.
Scot W.
John Wright
09-13-2010, 09:10 AM
Just didn't want you to expect huge weight reductions(it may or may not lose weight in large amounts)....like I said the fact that the suspension will work better/smoother will enhance the whole package. Simply freeing up the pivot points and bushings help both the ride and suspension aspects....and hopefully the car can shed a few pounds along the "weigh"....:fingersx:
nullshine
09-13-2010, 11:08 AM
So this is the drag coefficient for this car? (Not just a run of the mill Regal).
What aero mods have been done?
xxxturbo6
09-13-2010, 11:25 AM
What aero mods have been done? No this is for a regular regal and was tested by GM originaly. I just posted it seeing as there wasn't much info out there on drag coefficient on these cars.
No aero mods done, still all stock..
Scot W.
nullshine
09-13-2010, 01:16 PM
OIC, where did you get the coefficient of drag figures?
I'm not challenging its validity, just wondering if you have some kind of a list/chart/database or something that you'd like to share? :)
I've been looking for this kind of information for a while now, but can't seem to find much on G-bodies (as you said, there isn't much aero info around on these cars). Or even if you have figures for anything else (GM or otherwise), it would be awesome, just for curiosity.
Wicked car btw, and I love the "Function is Everything" motto!
CruizinKev
09-14-2010, 06:28 AM
looks great!!!
John Wright
09-14-2010, 06:54 AM
can't wait to see the after pics...the car is in good hands over there.
brrymnvette
09-15-2010, 04:17 AM
Awesome. This is going to be great info. I love the car, almost makes me wish I went the Regal route instead of the Malibu build.
BossaNova
09-15-2010, 02:13 PM
Glad you chose that car........looks great!
xxxturbo6
09-15-2010, 10:06 PM
It is 12:30 am here and I just walked in the door from DSE in Mooresville,NC. What a facility that is! We had to push Dale Earnhardt Jr's 1967 Camaro off the lift to make room for our TR Regal!!! https://static1.pt-content.com/images/noimg.gif I missed Kyle Bush by one day picking up his camaro....bummer. That would have been nice to see his too and meet him.
I can't even begin to say how nice everyone is at DSE, Kyle Tucker (owner) Made me feel right at home, He then changed clothes and jumped right in with his employee's and got filty tearing my car apart!! With everyone there being so nice, it was a bummer to leave... That place is "Top Notch" and the craftsmanship and fabrication those guys do just blows me away, These guys know what there doing!!
The complete DSE suspension is now on the car and "WOW" what a Big difference!!! It's Crazy!!
The following parts were installed:
FRONT:
* DSE Upper & Lower tubular A-arms w/Delrin bushings
* DSE Hollow Tubular sway bar
* DSE Front frame braces
* DSE 2" Drop Springs
* DSE Shocks
REAR:
* DSE Upper & Lower Adjustable control arms
* DSE Rear 1 1/8" Chassis mounted Tubular Sway Bar
* DSE Shocks
* DSE Drive shaft loop
Tomorrow we will be thrashing on the GNS car to get it ready for the start of Fridays RTTH event but as soon as I get an chance to go through the 200+ pic's I took and the (2) 90min videos I took I will post them here with a small detailed write up with measurements, Alignment info, Ride height info ETC...
We were ALL very supprised on how easy these parts went on the first G-Body Turbo Regal.. They literally just fell into place without hassle! I was amazing to even see the front springs go in so easy with a floor jack!! It's on video! https://static1.pt-content.com/images/noimg.gif
Okay, it's time to crash..Thanks for looking, Stay tuned for the interesting stuff!
Scot W.
lower90xcab
09-16-2010, 05:20 AM
cant wait to see how all this works...
xxxturbo6
09-16-2010, 08:12 PM
Okay, I have some time so I thought I would post up some pic's from my trip to DSE.
DSE Facility..
https://static1.pt-content.com/images/pt/2010/09/DSE001-1.jpg
Kyle (owner) & Ryan (Engineer of the G-Body products) taking it for a spin on the proving ground course Before the install.
https://static1.pt-content.com/images/pt/2010/09/DSE003-1.jpg
The car in the shop.....That's Dale Earnhardt Jr's Camaro beside it to the left..
https://static1.pt-content.com/images/pt/2010/09/DSE0061-1.jpg
The DSE staff doing some evaluating/documenting before the tear down..
https://static1.pt-content.com/images/pt/2010/09/DSE013-1.jpg
A look at the Front parts ready to install..
https://static1.pt-content.com/images/pt/2010/09/DSE004-1.jpg
A look at the Rear parts ready to be installed..
https://static1.pt-content.com/images/pt/2010/09/DSE005-1.jpg
Kyle Tuckers 1970 Camaro..
https://static1.pt-content.com/images/pt/2010/09/DSE012-1.jpg
Customers Car being built... My dream car!
https://static1.pt-content.com/images/pt/2010/09/DSE0081-1.jpg
Dale Earnhardt Jr's 1967 Camaro..
https://static1.pt-content.com/images/pt/2010/09/DSE010-1.jpg
Next, Give me a couple days to arrange the whole process into steps. I will also provide some good info to go along with each step that was made. A Bunch of stuff was measured/compared against the old & new products before installed. I will be adding every bit of info that was collected and the end results of the car now at the very end of this install.
Scot W.
John Wright
09-17-2010, 03:54 AM
Hurry back with all of the intricate details....:cheers:
xxxturbo6
09-20-2010, 04:56 AM
Okay guy's, The RTTH event is over and now I had time to put together some more pic's and info on the DSE build.
I guess I will start off with the front install. Overall all of these parts practically fell into place! None of it was a hassle to install nor did any of these parts give us a fit while installing. Everything has been Pre-measured to "Stock Specs" before they even go out the door so the fit is perfect.
Front Lower A-Arm installed
https://static1.pt-content.com/images/pt/2010/09/DSE028-1.jpg
Front Upper A-Arm & 1/4" Camber shim prior to install. The 1/4" shim from the DSE "Track Shim Kit" is used as a baseline for allignment.
https://static1.pt-content.com/images/pt/2010/09/DSE026-1.jpg
Front Upper A-Arm installed showing the shim installed as well..
https://static1.pt-content.com/images/pt/2010/09/DSE031-1.jpg
Here are the A-Arms installed and completed..
https://static1.pt-content.com/images/pt/2010/09/DSE050-1.jpg
Here we will install the front DSE sway bar.
In these pictures you see the DSE relocation bracket for the sway bar. This bracket is there to move the bar forward a bit from the stock location. (Not to worry it actually has MORE clrearance now over the stock one!) Must be due to the design of the DSE sway bar it's self.
https://static1.pt-content.com/images/pt/2010/09/DSE060-1.jpg
https://static1.pt-content.com/images/pt/2010/09/DSE059-1.jpg
Here is a few pictures of the DSE patented sway bar "Swivel Links"tm installed. These were designed to elliminate "Bind" and allow for the front sway bar to articulate better with the front suspension to keep all 4 tires planted to the ground. In these pictures you can also see the shocks installed.
https://static1.pt-content.com/images/pt/2010/09/DSE068-1.jpg
https://static1.pt-content.com/images/pt/2010/09/DSE067-1.jpg
Here is the Sway bar mounted..
https://static1.pt-content.com/images/pt/2010/09/DSE070-1.jpg
https://static1.pt-content.com/images/pt/2010/09/DSE071-1.jpg
xxxturbo6
09-20-2010, 04:57 AM
Here is a few pictures of the DSE front Frame Braces installed. There is still Plenty of room for front mount I/C pipes!
Note: These come with the purchase of the front sway bar!
https://static1.pt-content.com/images/pt/2010/09/DSE074-1.jpg
https://static1.pt-content.com/images/pt/2010/09/DSE075-1.jpg
https://static1.pt-content.com/images/pt/2010/09/DSE076-1.jpg
https://static1.pt-content.com/images/pt/2010/09/DSE077-1.jpg
The DSE "Drive Shaft Loop" installed..
https://static1.pt-content.com/images/pt/2010/09/DSE072-1.jpg
https://static1.pt-content.com/images/pt/2010/09/DSE073-1.jpg
xxxturbo6
09-20-2010, 04:58 AM
Here I did a few measurements with the Front old springs compared to the new DSE springs.
Here are the results:
"Stock 24 yr old spring Height" = 14-1/8" Tall
https://static1.pt-content.com/images/pt/2010/09/DSE017-1.jpg
DSE Front 2" drop spring Height = 12-1/16" Tall
https://static1.pt-content.com/images/pt/2010/09/DSE018-1.jpg
NOTE: Although the DSE springs are considerably lower prior to going in the car. The ride height only dropped 7/8" inch!
OLD "Front" Ride Height = 25.5" (measuring from ground to fender lip).
New DSE "Front" Ride Height = 24 5/8" (Measuring from the exact same place as we did for the Old ride height)..
SW.
xxxturbo6
09-20-2010, 05:01 AM
Okay here we will touch on the REAR portion of the DSE suspension install.
First I would like to touch base on the info gathered on the REAR springs of the old set up and the new DSE set up. On our old set up we used the Hotchkis 1" drop springs in the car.
Hotchkis 1" drop spring Height = 13.25" Tall
https://static1.pt-content.com/images/pt/2010/09/DSE022-1.jpg
DSE Rear 2" drop spring height = 12.25" Tall
https://static1.pt-content.com/images/pt/2010/09/DSE021-1.jpg
Rear Ride height comparisons:
"Old" Rear ride height = 26.75" (with Hotchkis 1" drop springs)
New DSE Rear ride height = 26-1/8" ( measured after the drive around) and in the same spot as measured before.
Now we will move onto the Rear suspension install.
Here is a picture of an Adjustable Rear Lower control arm installed and an Adjustable Upper control arm installed. These DSE rear control arms are exceptionally different over the rest of them out there today and the reason for that is DSE's patented "Swivel Link" tm System. These control arms actually swivel on one end allowing your 4-link rear end to articulate fully and keep all 4 tires planted on the ground. This was a speacial interest to me when I seen the demostration done on my own car. Once the whole rear suspension was complete one of the guys took his hands and placed them on one of the rear brake drums and moved the whole axle Up & Down with ease, Then he had me do it and look at the swivel links to see them move. AMAZING.. and Not one bit of bind at all!!! DSE told me that when people box-in the stock lowers that it actually takes "Flex" away that was actually designed to be there in order for this 4-link suspension to work. It worked out fine in a drag application but not when you want to keep all tires planted to the ground.
https://static1.pt-content.com/images/pt/2010/09/DSE043-1.jpg
https://static1.pt-content.com/images/pt/2010/09/DSE037-1.jpg
DSE Rear sway bar install pictures:
Here is a picture showing the "One" hole needed to be drilled to mount the bracket for the rear sway bar end links.
https://static1.pt-content.com/images/pt/2010/09/DSE035-1.jpg
https://static1.pt-content.com/images/pt/2010/09/DSE036-1.jpg
Here is the end link bracket installed.
https://static1.pt-content.com/images/pt/2010/09/DSE046-1.jpg
This picture shows the rear sway bar axle mount bracket installed..
https://static1.pt-content.com/images/pt/2010/09/DSE045-1.jpg
Here is a picture of the rear sway bar end links that also incorportate the pattented "Swivel Link"tm System. These end links are "Beefy" to say the least and they elliminate Bind!
https://static1.pt-content.com/images/pt/2010/09/DSE056-1.jpg
https://static1.pt-content.com/images/pt/2010/09/DSE053-1.jpg
xxxturbo6
Here is a picture showing the adjustability holes in the sway bar it's self! These holes are for moving the end link forward or backwards to change the ride of the car. Front is more for street and the rear is for a more aggressive ride.
https://static1.pt-content.com/images/pt/2010/09/DSE047-1.jpg
Here is the bar completed/installed..
https://static1.pt-content.com/images/pt/2010/09/DSE044-1.jpg
xxxturbo6
09-20-2010, 05:12 AM
I just competed in our anual RTTH event here in TN where we compete in an Autocross, Dragrace and a Speed/Stop Challange and the car was simply AMAZING!! It was flat on the autocross and still worked well on the dragstrip.
On the AUTOCROSS we finished 30th out of 79 cars overall with a best time of 1:15.2 That was a very respectable time but my next three runs got nixed so I couldn't try to better them, I was bummed because we were shooting for a 1:13.0 or even better but I was super happy with how the car handled and it's a testiment to how the DSE products work after just bolted in..
We finished with the car at DSE on Wedsday @ 8:30 pm and I didn't get home untill after midnight, then Thursday we buttoned a few things up and went to the Dragon on friday and the Autocross on Sat, then the dragrace & Speed/Stop Challenge. Pretty good for just installing it and one day later competing with it!!!
Here is a Picture from today in the burnout box which Gives you a good idea of how the Stance looks right now.. OHH and just to let people know, There was two people in the car on 2 out 3 of my Autocross runs and also two people in my car on the dragrace runs. So this should elliminate any "Does it rub" questions!
(Photo's curtesy of John Simerly)
https://static1.pt-content.com/images/pt/2010/09/DSC_0274-1.jpg
https://static1.pt-content.com/images/pt/2010/09/speedstopresults-1.jpg
https://static1.pt-content.com/images/pt/2010/09/20100919413-1.jpg
lower90xcab
09-20-2010, 07:07 AM
the car/dse parts look killer....
BossaNova
09-20-2010, 07:44 AM
I saw your car at RTTH & it was beautiful!
And you should be really proud of your time.
Do you have a time from last year to compare?
CruizinKev
09-20-2010, 08:27 AM
omg nice upgrade!!!! looks great!!! :cheers:
John Wright
09-20-2010, 09:18 AM
Nice pics and details....
redss86
09-20-2010, 09:31 AM
Stance looks awesome. I am sure it rides just as good.
xxxturbo6
09-20-2010, 09:42 AM
Do you have a time from last year to compare? Thanks Mark!
No unfortunetly I didn't run it last year because I just felt it wasn't ready being all stock so I stayed out of it, The only way to get a true comparison is to have the exact same track layout and that wouldn't happen so the times would be different anyways.. Ohh well, This is a good starting point!!
Thanks for the kind words everyone!
Scot W.
xxxturbo6
09-25-2010, 05:17 PM
Nice pics and details.... Thanks John!
Scot W.
Turbo Rob
09-25-2010, 05:45 PM
Hey Scott,
How much clearance is there between the sway bar and the differential cover? I have the TA Performance girdle/cover on mine which is quite a bit thicker than the stock stamped steel one. Want to make sure it will fit. I do like the way it wraps around the diff versus going under it.
Rob
xxxturbo6
09-25-2010, 06:22 PM
Hey Scott,
Rob Quite a bit Rob, I would say at least 3" from the closest spot of the differential cover. That was one angle that I forgot to get. If you want I can take a pic and post it..
I looked at that and thought the same thing, I used to have a T/A cover and it stuck out a bit farther than the stock one but once it was all installed it looked like it would clear no Problem..
Scot W.
Tony_SS
09-26-2010, 03:47 AM
Nice looking parts, great writeup too! I'm glad DSE is making something for the G-body world.
The Ttype looks great too!
xxxturbo6
09-27-2010, 12:32 PM
The Ttype looks great too! Thanks for the compliment Tony! If you need anything or have any questions in regaurds to this new suspension feel free to call.
Scot W.
Nothingface5384
11-28-2010, 01:19 PM
you convinced me that an auto car can do well in auto-x
but do you plan to go with a fay 2 watts due to the swivell links?
do you still plan to go ls1/4l80e? or you sticking to buick power ??
xxxturbo6
11-28-2010, 01:37 PM
do you still plan to go ls1/4l80e? or you sticking to buick power ?? Thanks for the compliments and the car will be even better next season..
I'm not quite sure what you mean by me planing to go with a fay 2 watts, I never planed on it at all and not sure what your meaning when you say "Due to the swivel links"? The DSE patented swivel link set up is simply remarkable on how it keeps the tires planted making the stock G-body 4-link suspension articulate Properly so i'm not really sure where this fay watts 2 talk came from..... Excuse me for being Confused..
For now it's Buick V6 Power all the way until we can't get any more progress out of it, Then maybe in the future it will be a LS3 & 4l65E or 6L80E...
Scot W.
Nothingface5384
11-28-2010, 01:56 PM
I know the swivell link makes the rear move so it'll not bind and lift tire/ or snap oversteer. This is a plus for hard street driving and auto-x events, I just figured since the DSEs swivell links allows for movement that an axle locater my now be beneficial?
Nothingface5384
11-28-2010, 02:06 PM
but since you have been running it, it sounds like the rear swivell links dont induce any lateral axle movement?
xxxturbo6
11-28-2010, 02:44 PM
but since you have been running it, it sounds like the rear swivell links dont induce any lateral axle movement? We haven't noticed any rub either on the frame or on the wheel well and on the inside of the tire to frame and it is so close that I can not get my index finger between them! Same goes for the wheel well lip to tire and still no rubbing so I can tell you that if it's moving, it ain't much!!
canadiantbone
12-19-2010, 02:27 PM
Looks killer ! I wish I could spend that much $ on my suspension .
xxxturbo6
12-19-2010, 02:41 PM
Looks killer ! I wish I could spend that much $ on my suspension . You Can! That's the beauty with the DSE suspension, it's all from one company so therefore you can buy it in bit's N piece's and have a killer suspension that was designed to work together as a complete set up.
Scot W.
SicMonte
12-25-2010, 05:31 AM
A may zing!!!!!!!!
xxxturbo6
01-03-2011, 09:52 AM
Okay I rescaled the car today after the DSE suspension products were installed. As seen on the first page of this thread you might have noticed that my corner weights were of quite a bit, here is a example so you don't have to go back to look at what they were.
Old measurements (Stock suspension)
997-* *-956 = (41 lb diff)
695-* *-741 = (46 lb diff) resulting in a 56.6% / 42.4% weight bias.
Now here are the measurements AFTER the DSE products were installed.
976-* *-979 = ( 3 lb diff )
728-* *-728 = (Zero lb diff) resulting in a new 56.8% / 43.1% weight bias.
I have the scales now at the garage and we will be doing some changes to better this current weight bias.
Scot W.
monteboy84
01-28-2011, 05:30 AM
Great write-up! Pretty amazing how the DSE kit evened out your corner weights. You said you're going to try improving these, I'm guessing you're planning to move some things around to change front/rear split?
-matt
xxxturbo6
01-28-2011, 05:41 AM
-matt Correct, We plan to get a fiberglass hood and see what that does,then possibly add weight to the rear to get to the desired weight bias.
monteboy84
01-28-2011, 05:46 AM
Cool, can't wait to see how that works out. Is your battery already in the trunk? If not, moving it to the center of the raised portion of the trunk would be a great start.
Thanks for all the pics,
-matt
xxxturbo6
01-28-2011, 08:36 AM
-matt Matt, At the moment it is still up front but were moving it back in the trunk after we see what the F/G hood does. Then we are installing the BAER track 4 front & rear set up, then another Scale to see what that done... "One step at a time, Measure, then take the next step"! :)
Scot W.
xxxturbo6
02-08-2011, 01:43 PM
2011 season up grade winter list....Getting ready for some more Auto-X and finally some Road course events!
*The BAER track4 kit for (Front & Rear) were ordered last week.. (Complete installation write up coming )
*The SCHROTH Rallye4 harness' were ordered today for (DR & Pass).. (Installation pic's coming)
*The turbo was sent in to have a special exhaust housing milled to fit my turbo to gain quicker spool up..
*The seat brackets were cut and lowered 1 1/2" - 2" to lower my center of gravity some and give me more room for the helmet...
*Alpine head unit and JL Audio speakers were installed for better sound quality...
*Still up in the air yet on if I want to add the GNX fender flare's and do the mods to the wheel wells like ASC done...
Scot W.
NASTY GN
02-08-2011, 06:52 PM
Looks like a fun month of modding ahead. I think you should add the flares and make a kit to duplicate the way the X was done. (fender,quarter cuts and brackets)
Stg1Regal
02-14-2011, 04:23 PM
Scot
I Agree with Nasty GN, those flares would look awesome and it should be done for clearance just like the guys at ASC did. Instead of flaring out the fenders like NASCAR did (wich I really want to do) I plan on doing the GNX flares the right way on mine.
Heres a Picture of a GN done in all white with the GNX flares to inspire you
https://static1.pt-content.com/images/pt/2011/02/DSCF0092-1.jpg
https://static1.pt-content.com/images/pt/2011/02/DSCF0093-1.jpg
Here's a pic of a Turbo-T DRBUICK from the V8BUICK.COM board, it has correct GNX mods done to use the Flares, he's running 17x10's with 285/40/17s on the fronts, & on the rears 17x11's with 315/35/17's and lowered.
