View Full Version : Retro LSX pan clearance
Jim98ta
09-09-2010, 03:59 AM
Hey everyone. I am putting an LS2 into a 69 Camaro and seem to have pretty tight clearance on the oil pan.
I am using Hooker adapter plates, Poly motor mounts, and small block engine stands. The pan is a Retro LSX pan which has a rounded bottom to it. It is just barely touching on the drivers side at the perimeter of the recessed section of the frame.
Has anyone else run into this? I think it might end up being OK, I don't have the trans on it yet so it might change a little.
Wanted to see if anyone else experienced this or has any thoughts on a way to get a little more clearance..
Thanks for taking a look at this..
CamaroAJ
09-09-2010, 04:05 AM
it will vibrate and drive you nuts.
Jim98ta
09-09-2010, 04:10 AM
I was a bit worried about that. Also worried it will mess with the knock sensors.
I'm thinking of adding a washer between the motor mounts and the adapter plates to see if that gets it off of the frame.
CamaroAJ
09-09-2010, 04:14 AM
it very well could cause a false knock.
Jim98ta
09-09-2010, 04:18 AM
Any idea how much space I need between the frame and pan for safe clearance?
CamaroAJ
09-09-2010, 05:07 AM
i would think 1/4" at the min would be ok. from the looks of your pictures i think i would shim the drivers side. the passenger side clears pretty nicely.
CarlC
09-09-2010, 05:08 AM
You may want to consider finding out if the poly motor mount manufacturer offers a taller version.
CamaroAJ
09-09-2010, 05:21 AM
looking at the picture maybe its there maybe not but there should be a preload shim between the mount and the adapter plate.
they also have these if you can't find a tall version like carl said.
http://www.jegs.com/i/Trans+Dapt/969/4125/10002/-1
Jim98ta
09-09-2010, 05:30 AM
Great info and thanks for the link. There wasn't a preload shim included with these mounts. I think I'll work on getting the trans on, then see where it sits. Then I can figure out the best place to put some shims/etc to get space. I'll look into taller mounts to see whats avail too.
BigMal69
12-17-2010, 08:50 PM
I also have the LHx pan from Retrolsx and have the exact same issue. It hits in the exact spot. Did you ever figure out a good solution?
overZealous1
12-19-2010, 10:27 AM
i have one too. using all solid mounts though so 1/8" clearance will be fine for me.
with my set up at 3 degrees though and maxing out trans height (without modding trans tunnel) the lsx pan still sits lower than the crossmember. this was the reason i bought the pan in the first place to NOT have that happen. my car is really low, so will have to be making a 1/4" skid plate for it now.
Jim98ta
12-19-2010, 01:29 PM
What I ended up doing was 'dimpling' the frame just a little, then I added one washer between the mount plates and the motor mount 'stands' that are cast into the block. I figured since the plates basically mount to pedestals on the block, a washer at that point would not hurt. With those two things done I ended up with about 1/4 inch clearance with everything in place.
dhutton
12-19-2010, 01:45 PM
This is the reason why I prefer the look of the Mast pan. It is not as deep at the front of the pan. When I tried to order it a few months back it was not available yet.
http://www.mastmotorsports.com/2010/product-view.php?cat=Oil%20Pans&id=160
