View Full Version : Minitubbed TCI 4 link or TA rear suspension vs. DSE for tire clearance
Whistler
09-07-2010, 06:55 AM
I am about to do a minitub rear suspension in a friend's 68 Camaro ,he is looking at either TCIs TA or 4 link with panhard rod. Either will be installed with DSEs minitubs.
TCI states up to an 11" wheel w 305 wide tire can be used in this application. What is the difference with the rear suspension in regards to tire clearance vs. DSEs Quadralink?
I have DSE tubs and Quadralink in my 67.. it sits low with 18x12s and a 345/30/18 BFG dragradial.
Is the difference in the suspension/control arms, or in how the tubs are installed?
TCI Engineering
09-07-2010, 09:30 AM
Our link bars attach to the outside of the frame vs. DSE that sit inboard. We also use a coilover crossmember that covers the whole frame inside and out. Having said that we have had many of our customers use a 335 tire on a 12" wheel with our rear kits. The DSE tubs cut into the frame so you will have to modify our crossmember to make it fit.
Here are some pics I have taken because this question comes up fairly often.
This is our car on a lift with 18"x11" wheels and 315 tires. Keep in mind we are not using a DSE tub but we did cut into the frame about 3/8".
-J
Whistler
09-07-2010, 07:51 PM
Those that fit a 12" wheel w 335s... did they have to modify the lower link bar? Or was it all in the tubs and the ends of the crossmember?
TCI Engineering
09-08-2010, 07:15 AM
No mods to the link bars at all. We typically leave the outer portion of the crossmember unwelded in these situations to make your life a little easier. :cheers:
-J
