View Full Version : JCG Restoration & Customs 71 Camaro L99/4L80
Cris@JCG
09-05-2010, 01:47 PM
Here is a project that came in that was only gonna get a paint job & a new GM crate motor with 700R.. but as the owner saw that I was doing a bunch of LS Conversion.. Project took a complete turn around.. I found a L99/6L80 out of Cleveland Pick A Part out of a 2010 Camaro with 1700 miles on it..
Suspension upgrades: DSE Stage 1 front suspension upgrade with steering box, koni shocks, rear leafs, Wilwood disc brakes on all four corners
Edelbrock Headers, Custom engine mounts & transmission, MagnaFlow exhaust system, Ron Davis Radiator, Speartech harness rework, Ricks Hot Rod Gas tank
& much more to come!!
https://static1.pt-content.com/images/pt/2010/09/P5270007-1.jpg
Where it is as of yesterday!
https://static1.pt-content.com/images/pt/2010/09/IMG_0377-1.jpg
Pics of transmission tunnel cut out.. Huge transmission!!
https://static1.pt-content.com/images/pt/2010/09/P3080050-1.jpg
https://static1.pt-content.com/images/pt/2010/09/P3080052-1.jpg
https://static1.pt-content.com/images/pt/2010/09/P3080055-1.jpg
https://static1.pt-content.com/images/pt/2010/09/P3080056-1.jpg
Cris@JCG
09-05-2010, 02:00 PM
Pics of the assembly of the sub-frame!
https://static1.pt-content.com/images/pt/2010/09/IMG_0369-1.jpg
https://static1.pt-content.com/images/pt/2010/09/IMG_0370-1.jpg
Edelbrock Headers fit nice!!
https://static1.pt-content.com/images/pt/2010/09/IMG_0371-1.jpg
https://static1.pt-content.com/images/pt/2010/09/IMG_0372-1.jpg
Output shaft on transmission got tricky!!
https://static1.pt-content.com/images/pt/2010/09/IMG_0373-1.jpg
We made our own hub to be able to build a driveshaft..
https://static1.pt-content.com/images/pt/2010/09/IMG_0374-1.jpg
https://static1.pt-content.com/images/pt/2010/09/IMG_0375-1.jpg
Here is a shot of it assembled in the car.. Making a custom spacer to fit the alternator in the Corvette factory position & custom A/C brackets..
https://static1.pt-content.com/images/pt/2010/09/IMG_0378-1.jpg
jocko124
09-05-2010, 02:03 PM
Looking GOOD!
67 ls1 vert
09-05-2010, 02:33 PM
wow, you work fast. Started it today and almost have it finshed. good job. :)
Guy is going to love it. Looking good.
bonecrrusher
09-05-2010, 03:38 PM
Title of the thread is wrong... should be 6L80E me thinks....
Motown 454
09-05-2010, 06:02 PM
It looks great. It should be asweet driving car with that combo in it. What color is that??
CruizinKev
09-05-2010, 07:15 PM
very nice! :twothumbs
Cris@JCG
09-06-2010, 09:00 AM
GM Atomic Orange..
Boerger
09-06-2010, 04:45 PM
Car looks great! What paint was used for the subframe and firewall?
srh3trinity
09-06-2010, 05:58 PM
Are you staying with the 2010 Camaro accessory drive? AC? Why the custom engine mounts as opposed to an off the shelf conversion plate? Is there any setback?
Cris@JCG
09-06-2010, 06:42 PM
We are only using the water pump, harmonic balancer... gonna use Corvette alternator/Power steering bracket to place it high to clear the gear box & steering linkage.. We are making our own A/C brackets to use a saden 7 compressor compatible with Vintage Air system
LS conversions are pretty new to 2nd gens.. all we did was modify the stock transmission support & build new frame mounts.. easier for us to & place the motor where we wanted it
srh3trinity
09-06-2010, 06:46 PM
Thanks, I am trying to soak up as much as possible for a future swap.
Cris@JCG
09-06-2010, 06:55 PM
SEMS trim black
Cris@JCG
09-06-2010, 06:57 PM
Your welcome.. let me know if you need more info.
bonecrrusher
09-06-2010, 07:56 PM
I spy the title change.... Swap looks awesome!!
Cris@JCG
10-06-2010, 06:44 AM
I buy all my exhaust kits from Summit Racing..
magnaflow (http://www.allexhaust.com/)
where is the best place to get it?
maxxom
12-11-2011, 10:16 PM
Did you ever complete this build? If so, do you have any pictures of the engine bay? I am doing the same L99/6L80e swap.
