View Full Version : Injection cleaner
paul67
09-05-2010, 11:09 AM
I have a 95 LT1 vette engine i my 67 camaro and are thinking of using a cleaner,the car has been stood for a few months and is have problems starting and running.
1970 TT Rustang
09-06-2010, 11:34 AM
i use cheveron techron with no problems good stuff
paul67
09-07-2010, 10:58 AM
CamaroAJ
09-07-2010, 11:12 AM
thats who makes it for GM too.
digger1978
09-10-2010, 09:15 AM
+1 on Chevron with Techtron. Go to Costco or Sams Club and pick up a 6-pack of it. I use it in all my passenger cars.
67zo6Camaro
09-10-2010, 09:56 AM
I also had injector issues after the motor sat during my build. I had two sets of injectors. One set were just slightly dirty, so I pulled them out and pulled the rubber seals off. Then I put them in kerosene over night. This seamed to clean them better than just using an additive, if needed. The other set of injectors, the better ones that were clogged more, I took to an injector shop in Torrance CA. 7 of the 8 were fully clogged. For +-$25.00 each, they were able to clean, repair, and flow check the injectors to match. Came with new screens and o-rings....and this was cheaper than buying new ones. Good luck
Brett
My427stang
09-10-2010, 07:46 PM
Here's who does mine, a week or so and you get them back all cleaned and mapped. If they are good, he just flows them and wont charge you.
http://www.cruzinperformance.com/fuelinj.html
724tim
09-10-2010, 08:15 PM
I use these two.
Lucas & Seafoam
http://www.lucasoil.com/products/display_products.sd?iid=26&catid=8&loc=show&headTitle= - Lucas Fuel Treatment
http://www.seafoamsales.com/motor-treatment.html
