69camarokid
09-04-2010, 10:09 AM
69 camaro.
11 inch power discs all four corners
OK so heres the senario.
About 3 months ago the brakes started to get really mushy.
Turns out that one ofmy rear brake lines had snapped off the end section that allows it top seal and keep air out. So i replaced that part and bled the brakes. They felt solid with the car off, once it was on they went mushy again.
Thats when i noticed the master cylinder was leaking. So i just replaced that this morning with a new one, then proceeded to bleed the brakes. The pedal felt solid after, then i started the car and it went straight to the floor mushy again. Ideas?
Here is one question i have. when i bled them the second time i noticed in the rear not a single gurgle or bubble cameout, just steady streams of power steering fluid. This was after 6 or 7 pushes of the pedal. In the front on the passenger side i got lots of air, nad then finally steady streams. Left front was nothing but steady streams.
Any ideas on what may be causing this? thanks
