Pro-Touring.com
General Technical Discussion
Suspension
> speed tech sub-frame what oil pan
View Full Version :
IBDMANN
08-30-2010, 09:02 PM
I've got a speed-tech subframe. can you fit a performance oil pan when using a sbc or am I limited to a stock pan only? thanks
killer69
09-02-2010, 03:03 PM
almost any oil pan that is no more than 5" deep and then the sump will work.
here are some moroso #'s that will work
21308
21017
20194
20195
as long as the main sump is flat and not tapered to the rear sump you will be fine
IBDMANN
09-03-2010, 06:09 PM
thank you
