View Full Version : Rear Suspension
TERMN8OR
08-29-2010, 03:46 PM
Are there any completely bolt in 4-link package for a 69 Camaro ? Looking for something that doesn't need welding and is top quality.
TnBlkC230WZ
08-29-2010, 06:12 PM
Have you checked out Chassis works? They have a triangulated 4 link. It is bolt in if you get there axle housing. If you use your axle, it only requires welding of the two upper link mounts to the axle. You can have a shop do that before you put the rest of it in.
I'm looking hard at this setup for my Nova
http://www.cachassisworks.com/download/BuyersGuides/BG_400/BG_400_WEB.pdf
IBDMANN
08-29-2010, 07:28 PM
installed that set-up in my 69 camaro. The detailed instructions on their website with quality pictures really help. There is some welding invovled. I'm very happy with this triangulated 4-link.
T-CHRGD
08-29-2010, 07:35 PM
Give Mark at SC&C a call Monday. He can give you lots of good info on the Chassisworks set-ups.
610-346-8154
ProdigyCustoms
08-30-2010, 03:23 AM
G bar is a weld in. Prodigy Bar is the only bolt in. Only welding required is some small tabs on the axle tubes.
The AirBar is now available as a stand alone 4 link and can use either coilovers or Shockwaves. http://www.ridetech.com/store/suspension-components/airbar/1967-1969-chevy-camaro-firebird-airbar-systems.html
This is the exact setup that we have under Velocity for the last three years. It gets driven fairly hard. :)
TERMN8OR
08-30-2010, 12:32 PM
So with any of these systems, there is some welding required. I guess there is no true bolt in type of system.
dhutton
08-30-2010, 01:05 PM
Not unless you buy the rear end with the brackets already installed. Then you have a couple of options. If you have a 12 bolt rear end you can likely sell it for good money to offset the cost.
ProdigyCustoms
08-30-2010, 01:44 PM
That Hutton guy is always giving good advice.
If you want a total bolt in solution, we can do a ready to go 12 bolt with all the brackets welded, and if your 12 bolt has good guts in it, you can sell it and probably have very little net cost for the new one.
zbugger
08-30-2010, 02:16 PM
I know Heidt's also has a bolt-in rear link suspension. I think it comes with a 9" housing. They also have a bolt-in IRS setup. I saw it yesterday at the Goodguys show in Pleasanton. It looks, how should i say, interesting...
MonzaRacer
09-01-2010, 08:52 PM
go with air ride, hands down best suspension i have ever owned.
killer67
09-01-2010, 10:49 PM
Airride is easy install and pretty decent price point
CarlC
09-01-2010, 11:32 PM
Was it the orange 2nd gen car?
BMR Tech
09-08-2010, 09:30 AM
Whether you have a 10 bolt, 12 bolt, or 9" our torque arm kit is 100% bolt-in, no welding required.
More info HERE (http://www.bmrfabrication.com/F2.htm).
damn thats sexy!!!!!
zbugger
09-08-2010, 11:10 PM
No Carl. It was a Mustang. It was on a rotisserie in their booth. Interesting display.
Roadrage David
09-08-2010, 11:14 PM
In the eurly days of fighter planes in the sec word war.
there was this quote from a very wel known disgner engeneer.(forgot his name)
and he said ""If it looks fast it is fast""
that Torque arm looks fast!! and yes Sexy as wel.. Thats why i got it hahahahah
BMR Tech
09-09-2010, 06:59 AM
Sexy AND she puts out! :fingersx:
TnBlkC230WZ
09-10-2010, 05:41 PM
Frank, I read through the G-Bar and it said you only need to weld the tabs for the upper links on to the axle. Is this correct? I'm looking for a bolt in system too. If I'm going to weld, I'd look at the Art Morrison system.
ProdigyCustoms
09-10-2010, 06:05 PM
The G bar requires ZERO cutting and mild welding to the frame rails and welding the tabs to the rear housing.
With our Prodigy Bar, it bolts into the frame rails and you weld tabs on the rear end housing, OR we also have jig welded rears available so you can bolt it in. We even have pre bent tailpipes for the system
TnBlkC230WZ
09-10-2010, 06:48 PM
Do the Jig welded ears work on a 12 bolt?
6t9 337
09-10-2010, 07:12 PM
Is that "interesting" in a good way?
ProdigyCustoms
09-11-2010, 03:31 AM
Our bolt in jig welded rear for our Proigy Bar rear suspension can be done in 12 bolt, 9" or Dana 60.
TnBlkC230WZ
09-11-2010, 06:21 AM
Do you have any detailed pics, installation instruction and shock & spring spes. I'm ordering somthing this week.
also, what size tires and rims can you run? I'm putting DSE tubs in as well. I'm installing this on my stock 12 bolt rear
