fordsbyjay
08-19-2010, 02:00 PM
First off, this post applies to both brakes and rearend so hopefully it will be alright in the brake section.
I am just about at the point where I need to order my rearend and brakes. I was going to order a Moser full floater setup but after talking with Moser tech yesterday the OD of their hub is 3" and I don't have a large enough center in my wheels. After some searching I found a unit from Schreiner Enterprises (www.9inchfloater.com). Their snout is 2.6" which and only sticks out 1.125" so they will clear my cobra R wheels. I spoke with Jason @ GMR awhile back and I believe they use the Schreiner ends on their housings but I don't like the look of a fabricated housing (personal taste).
So, I spoke with Ron Schreiner yesterday and they can make a rearend to my specs no problem. Ron said they could make the rotor adapter for whatever brakes I want to use.
The next issue is the brakes. I have searched and read a multitude of brake rotor/caliper threads here on the forum and there is some great information but I am more confused now then before. :scared: First off none of them apply directly to FF housings vs a conventional setup. Besides the physical difference is there any different needs based on the FF housing? One of the threads I read here (https://www.pro-touring.com/forum/showthread.php?t=70743) mentions all kinds of different calipers. We had talked about my front brakes in this thread (https://www.pro-touring.com/forum/showthread.php?t=65540) but the requirements for the rear seem quite small compared to what I see in the Wilwood big brake kits.
I was thinking along the lines of the wilwood 120-7568 calipers seen here (http://www.wilwood.com/Calipers/CaliperProd.aspx?itemno=120-7568-RS) and the wilwood 160-2540 12.72x1.25" rotors seen here (http://www.wilwood.com/Rotors/RotorProd.aspx?itemno=160-2540). Obviously this is bigger than I need but I was thinking it would leave room to upgrade the front end when I get there. Comments and suggestions would greatly be appreciated. I should also mention that I had budgeted $1000-$1100 for rear brakes and these fit that requirement well.
