View Full Version : Power steering upgrade belts and pulleys.
rosslord
08-18-2010, 05:11 PM
I am looking to upgrade my '67 El Camino to a short ratio power steering box. Currently, it has no power steering. I'm wondering what I need to drive the power steering pump. I currently have a single grove crankshaft pulley that is driving the water pump/fan and alternator. I am not considering a serpentine system right now, as I expect I'll replace this motor in a year or two. I want to get the upgrade done cheaply and easily for now.
Do I just need to replace the crankshaft pulley with a 2-grove pulley and drive the power steering pump off the 2nd grove, or is the solution more complicated than that?
jocko124
08-18-2010, 05:39 PM
Do I just need to replace the crankshaft pulley with a 2-grove pulley and drive the power steering pump off the 2nd grove?
I'm converting my Cutlass 2 PS and I'm have a 2 groove pulley. The first one drives the alternator and the second (inner) one will drive my new PS pump. Having said that, I'm running a saginaw TC pump and am having the bracket fab'd for me since I can't buy one off the shelf.
rosslord
09-16-2010, 06:10 PM
Ok, so I have a power steering pump now, and I have a two groove pulley installed on the crank. The problem I have is that my crank pulley, water pump, and alternator are all driven off the inner pulley groove. I'm assuming that I can't drive the all the accessories of a single belt that wraps around all four pulleys along the inner groove, so I'm not sure what to do next.
Should I put two grove pulleys on the alternator and water pump and drive those off the outer groove and the PS pump off the inner grove? Can I drive the PS pump off the outer groove from the crank pulley, sticking out in front of the other belt?
Thanks for any help!
??? pulley science???
1969 and up cars with long water pump
pre 1969 cars short waterpump
rosslord
09-17-2010, 06:02 AM
Rod - I think you've got it. In your second pic ("pre 1969 cars short waterpump") the 327 w/ PS layout seems to match exactly what I need. Driving the alternator and water pump out of the inner groove of the crank pulley, and driving just the PS pump out of the outer groove.
Thanks for the help.
