View Full Version : Bead Rollers
ProTouringCuda
08-18-2010, 11:17 AM
OK - looking into a bead roller. What's recommended? Eastwood? Woodward Fab? Irvan Smith?
What do you have, and what do you like don't like about it?
Thanks in advance for the help.
wiedemab
08-18-2010, 11:21 AM
I have an older version of the Pro-Tools. I'm pretty happy with it. If I were going to do a ton of bead rolling I would probably look into the Mittler Bros with the foot pedal control.
DynoDon
08-18-2010, 11:37 AM
I have a Harbor Freight and it's a piece of crap! It deflects under the pressure of the dies and causes the bead to wander.
John Wright
08-18-2010, 11:47 AM
http://trick-tools.vansantent.com/tools/Bead%20Roller
fletcherscustoms
08-18-2010, 11:58 AM
have this one and love it so far.
http://vansantent.com/sheet_metal_machines/bead_roller.htm
edog1
08-19-2010, 11:36 AM
X2 or if work by yourself
fordsbyjay
08-19-2010, 04:50 PM
x2 for me as well. I also have a HF one and it is a real POS. If you search youtube there is some good videos to help you learn. You can also see how to beef up the HF unit and add a drill for power if you are on a budget.
chassisguy
08-19-2010, 06:42 PM
Baileigh sells a nice one that is variable speed heres a little of my work....
https://static1.pt-content.com/images/pt/2010/08/GetAttachment-1.jpg
https://static1.pt-content.com/images/pt/2010/08/GetAttachment3-1.jpg
https://static1.pt-content.com/images/pt/2010/08/100_4528-1.jpg
https://static1.pt-content.com/images/pt/2010/08/100_44361-1.jpg
https://static1.pt-content.com/images/pt/2010/08/100_4656-1.jpg
https://static1.pt-content.com/images/pt/2010/08/100_4657-1.jpg
chassisguy
08-19-2010, 06:43 PM
Bailiegh Industries
gearheads78
08-20-2010, 02:52 PM
Bailiegh Industries
That is the one I have been eyeballing myself.
coolwelder62
08-21-2010, 06:39 PM
I have a mitler's bros. std. model 24 inch,power w/foot pedal.Work's great, I would like to upgrade to a 36 inch w/ HD. motor so I could bead roll 16ga. Roll's 18ga. great . So if any one would like a good deal on a 24 in. power MB. give me a call day's 785.594.7481,eves 785.594.3299.Thank's Scott.
ProTouringCuda
08-25-2010, 10:56 AM
Ok - now for a newby question: looking at the SVT panel - is the "SVT" logo actually raised, or is the outline a bead? If it's all raised - how did you do that?
BAILEIGH INC
11-02-2010, 09:24 AM
Check it out! http://www.bii1.com/videos/bead-roller-br18E.php
parsonsj
11-02-2010, 10:38 AM
Sigh. I would love to have such equipment... my $90 bead roller is a piece of crap. It takes two people to use it (1 to turn the crank, 1 to feed material).
Though it did have its fun: my wife wouldn't help me anymore since I had a tendency to raise my voice when she didn't understand what I wanted her to do. So I invited the hot neighbor lady to come over and turn my crank. :)
jp
BAILEIGH INC
11-02-2010, 10:46 AM
https://static1.pt-content.com/images/pt/2010/11/dicepanels-1.jpg
wellis77
11-02-2010, 10:57 AM
Since cost is an issue for me. I'll probably be buying the Woodward. Found a couple links that talk about reinforcing them to eliminate flex. This link shows adding an electric motor as well. Afterward he was able to bead 16ga. http://www.offroadfabnet.com/forums/showthread.php?t=3403
Another one on the hamb: http://www.jalopyjournal.com/forum/showthread.php?t=85823
If nothing else it's an option that will do the job and not break the bank.
Surprised you haven't gone down this road with yours JP.
parsonsj
11-02-2010, 11:21 AM
It's not that mine flexes (that I've noticed). All the threads are suspect in the carrying blocks, there's a lot of end play, the shear doesn't work, and the dies aren't smooth. But the biggest problem is that the motor doesn't move smoothly, because it's human-operated. Adding a motor to it, fixing the dies, etc. would be polishing a chunk of coal and wanting a diamond.
One of these days...
jp
wellis77
11-02-2010, 11:29 AM
What brand is your roller jp?
parsonsj
11-02-2010, 11:54 AM
It's from Harbor Freight.
Dave Maxwell
07-10-2011, 08:37 PM
I have the mittler power drive 24 and I am very happy with it. Still learning though
