View Full Version : Should I move the engine back 2"?
GRNOVA
08-18-2010, 02:44 AM
Is it worth the effort to move the engine back two inches in my 65 Nova?
What am I really gaining an what are the benefits?
ProdigyCustoms
08-18-2010, 04:22 AM
In fast math you will move engine and trans, (about 800LBS). So assuming the engine trans package is 60" from nose to tail, in very fast math it weighs about 13LBS per inch. So moving 2" you will move about 25LBS from the nose to the tail.
Lets say youy start at 1550LBS F and 1200LBS R, so about 56.4% F and 43.6% R, and you move 25LBS making it 1525LBS F and 1225LBS R, you almost move it to 55.5% F and 44.5% R. A move of .9%. Almost a full percent of weight bias change.
The huge advantage though is the adility to put a cooling system in it. The Chevy 2s are limited badly on how thick a radiator and electric fan set up they can take. Moving the motor back will give you room for some badd ass fans.
And moving the 25LBS does not suck either
GRNOVA
08-18-2010, 04:59 AM
Wow, After reading that Frank, I understand exactly what you are talking about. thanks for the explanation.
Bryce
08-18-2010, 05:39 AM
I say do it!
CamaroAJ
08-18-2010, 05:22 PM
i moved mine back about 4-5 inches. home depot is your friend. my engine bay is 5 cubic yards bigger lol
GRNOVA
08-18-2010, 06:19 PM
I hear ya AJ, I just finished moving mine back 2 inches and everything clears good. Just fabbing up trans mount.
Jasons72
08-18-2010, 08:41 PM
Wow that was fast!
ArtosDracon
08-18-2010, 10:41 PM
Wheel Barrow FTW!
64LS1Nova
08-19-2010, 09:31 AM
Is that the Heidts front end? Which oil pan are you running. That looks to be back a good bit farther than mine.
Frank
John Wright
08-19-2010, 09:56 AM
Plus...your drive shaft loses some weight as well :) ...(gets shorter)
GRNOVA
08-19-2010, 10:32 AM
Frank
Yes it is a Heidts clip.It is a stock 2002 Camaro pan. Remember I made the plates for the engine mounts 2" longer to move the engine back.
64LS1Nova
08-19-2010, 10:41 AM
I'm guessing you modified your firewall then. I have the same combo and my crossmember sits about 3/4" in front of the sump part of the pan. looks like I could go back about an inch before hitting the firewall. I was making preparation to move mine back also, but I scaled the car it's 50.2%front and 49.8%rear. So it's prolly not worth my effort.
CamaroAJ
08-19-2010, 06:26 PM
its not done yet but here are a few shots.
the engine is set back pretty far. about axle centerline
silver69camaro
08-20-2010, 06:37 AM
Good job, I wish more people would realize the benefits and do what you did.
LowBuckX
08-20-2010, 09:06 AM
Did you and frank use the same wheel barrow? looks like he used the front on Unfare and you used back...lol
CamaroAJ
08-20-2010, 03:14 PM
we recycled. same brand just the smaller 5 cu. yd. franks is 6 cu. yd.
68sixspeed
08-24-2010, 05:48 PM
ok, that is one of the more clever repurposed things I've seen... firewall mods from the depot or tractor supply!
