View Full Version : ordering a speertech harness... need your input.
67 ls1 vert
08-14-2010, 11:31 PM
Called John over at speertech and talked about ordering me a new custom wiring harness. I'm sure there is a few of you guys that are using his harness.
What can you recommend before I order it? He said that the custom harness comes with 4 extra feet of lead for the head unit to the computer. I was thinking about drilling a hole above the trans right behind the engine. About where the trans bolts to the engine.
I was going to give him my harness but he will not extend it, just strips out the wires that are not necessary.
Can I get away with the stock length through the trans tunnel?
Also, where do you guys mount the computer port plug at?
I just want to make sure before I order it I get some imput from you guys that have already made one.
Thanks.
GRNOVA
08-15-2010, 06:23 AM
Good morning Vert,
I just talked to John last week also, are you buying the computer and harness from him, He told me he can make it how ever I want it . I am putting mine in the glove box with the port also. I looks like we are doing a similar project just different cars. We will have to talk!
67 ls1 vert
08-15-2010, 11:51 AM
Hey Tim, no I'm going to use my own computer that I have.
$350 seems kind of steep for a 4 foot tail but in sure there is more to it I'm sure.
Just have to find a good tuner in my area.
What are you going to do with yours?
kochevy67
08-15-2010, 01:10 PM
I used a stock harness and mounted inside the car behind the dash, the wires were long enough. I also drilled hole through the firewall just above the bellhousing.
67 ls1 vert
08-15-2010, 01:36 PM
hey Kochevy67, Did you modify your own harness or did someone else do it? Can I see some pictures? I'm sure there is a lot of people that would benefit from it too.
kochevy67
08-15-2010, 02:52 PM
I would love to take pics but the dash is already back in. I did have to buy a small piece from Speartech. The wiring I bought was to operate the drive by wire and the fan relays, other than that I used the factory harness. If I dig up some pics I will post them.
