josht
08-13-2010, 04:19 AM
I have a zero mile 2007 L92 that needs to have the following done:
Katech A1 rod bolts
ARP Head Stud kit
ARP Main bolt kit
LPE 3 Bolt conversion kit
3 bolt Comp Cam
Powerbond underdrive pulley
Edelbrock 2 piece timing cover using a seal from a LS3 cover and sensor from the VVT cover
- hone, align or deck the block as needed.
Yella Terra 1.7 rockers on a set of TFS/TEA LS3 heads.
Install a smaller power steering pulley
I have all the parts, bolts,studs, gaskets. The L92 has original heads on it, no intake, no fluids, only VVT water pump. The L92 can be put on a pallet, currently sitting in the GTO.
Engine is located in Glen Cove, NY 11542
any shop recommendations and cost estimates?
Katech A1 rod bolts
ARP Head Stud kit
ARP Main bolt kit
3 bolt Comp Cam
