View Full Version : body bushing help?
astross89
08-12-2010, 04:54 PM
I have a 68 camaro and im putting the body bushings on and need to know if the thicker bushing mounts in the back part of the subframe or the middle? I have no paper work. any help would be good. thanks
astross89
08-14-2010, 03:54 AM
any one? someone has to know.
dhutton
08-14-2010, 05:00 AM
Do a search over on camaros.net
68Formula
08-14-2010, 05:54 AM
I always thought the middle and rear mounts were thicker than the core support. You only have one set thicker than the other two?
astross89
08-14-2010, 07:20 AM
I will be going to solid mounts later but the set of rubber mounts i have the middle and rear are to diff. thickness. maybe a bad set? and the core support bushing i cant mistake which ones those are.
08-14-2010, 08:47 AM
thats where we have always put them ( when we used to use them). It might be dependant on the manufacturer. It would help to know which brand.
https://www.pro-touring.com/forum/showthread.php?p=660636&highlight=body+bushing#post660636 see here....for Global west solids
Vince
dipren443
08-14-2010, 03:01 PM
The oddball pair go on the core support. The back 4 are the same. Whichever is the oddball (thicker or thinner) go on the core support. It is all manufacturer dependent.
