View Full Version : I Need Help With Hood Clearance Issue On My Latest Project
vintageracer
08-11-2010, 10:44 AM
Any Suggestions????
critter
08-11-2010, 10:51 AM
Well, first, you need a bigger motor...
Randy67
08-11-2010, 10:53 AM
Me thinks you need a bigger car, a lot bigger car. You could always try a hood off a Semi, it might work.
Bill Howell
08-11-2010, 01:02 PM
6" cowl should do it. 6" fiberglass cowl hood fixes anything.
chr2002ca
08-11-2010, 01:58 PM
That mutha is gonna push hard in the corners. I'd move the engine back a few inches.
buickfunnycar.com
08-11-2010, 02:03 PM
Driveline angle looks dead on...
novaderrik
08-11-2010, 02:58 PM
or just mount it in the back with a Porsche transaxle..
sik68
08-11-2010, 03:26 PM
I did that same swap. I made it work with a flat hood but you need to use the ATS motor mounts. The only problem I had is that you may run into clearance issues with the headers hitting the steering box.
coolwelder62
08-11-2010, 05:35 PM
You are not doing your engine swap's right.Because I have seen that swap done in a smart car w/no hood mod's.:fingersx:
