View Full Version : will these work on my 68 camaro mono leaf rear
speedshftr
08-10-2010, 06:41 PM
have a 68 camaro with a mono leaf rear.it needs about 3 inches lowered in the rear.the car is a slow cruiser and not a high hp car.i need inexpensive fix to get the rear down.will thse work for my setup.im running 18 inch rushforths also.
http://cgi.ebay.com/ebaymotors/67-68-69-CAMARO-LOWERING-3-REAR-LOWERING-BLOCK-KIT-/300314913046
08-10-2010, 10:15 PM
I would not go over 1.5" drop using this method. Usually 1" is max, but on a lower hp car I think you could get away with 1.5". going 3 inches is going to cause trouble with shock length & probably some other issues.
David
redfire69
08-11-2010, 03:45 AM
Every now and then you'll see a used set of DSE 3" drop springs for sale. Maybe post in the wanted sections...
