View Full Version : GM Fastburn Head to Header Port Issue
kryptik
08-05-2010, 10:16 PM
Hello,
I have a zz383 engine with GMPP Fastburn heads; the exhaust ports on these are "d-port." I have headers (Dynatech 1-3/4") that work well as far as interfacing properly with the "D" shape (i.e. they do not hang down and block the top of the "D").
The problem I am having is that because these headers are completely oval, they hang DOWN too far from the flange surface. Long story short, when the headers are bolted and torqued, a roughly 1/8" portion of the header primary is under-hanging the flange and is completely open and exposed. I can't do anything with the gasket itself to seal it up, and I feel that this is far too large of a gap to not worry about; it will cause a major exhaust leak, will cripple any notion of using a wide-band in the future, and may even spit fire.
My only idea is to have a qualified welder lay down a bead inside each of the primary tubes to cover up this exposed area, and then to machine the surfaces flat once more. Any other ideas/input would be greatly appreciated. I am also on a very limited time schedule.
Thanks a lot for the help everyone, cheers!
PARKERRS
08-06-2010, 07:17 AM
I know your exact problem. I have the fast burn 385 crate motor in my grey car. I went through 8 sets of headers test fitting when I built the car and had the same problem with all of them.
A flange for LT-1 chevrolet heads works perfect and so do the gaskets. I had a company called Stan's headers out of Washington build a set of their try-y headers using the LT-1 flanges and all is great.
You can contact Stan's and have a set built or you could purchse a set of LT-1 flanges to weld on your headers. Or the expensive route is to go and have a set custom built. Stan's was a good cross between custom built and off the shelf. 3/8 flanges, thick tubes and great workmanship. Stan used to be connected with the original Doug Thorley designs and manufacturing in the 60's.
kryptik
08-06-2010, 11:03 PM
Sounds good I'll give Stan a call on Monday, thanks for the referral.
On a side note...how do those headers fit with angle plug heads and angled spark plugs (not sure if your heads are angled)?
72elco
08-07-2010, 12:09 AM
I have this same set up. zz383 D port heads. I bought the ceramic coated headman headers "D port" for it and it works perfectly. they were pricey but may be cheaper than having something custom done for you.
CarlC
08-07-2010, 06:48 AM
It's very common on standard flanges to slot the bolt holes in order to move the header up. The FB heads have a raised port which makes most traditional port location header flanges have gaps.
PARKERRS
08-07-2010, 12:52 PM
My heads are identical to yours. no fitment issues at all.
Landon
04-11-2012, 11:06 AM
I noticed you have a tru trac rear end in your car. How do you like it? Does it act like a tru posi, are you able to burn out both tires at the same time?
Landon
Hello,
