kryptik
08-05-2010, 10:16 PM
Hello,
I have a zz383 engine with GMPP Fastburn heads; the exhaust ports on these are "d-port." I have headers (Dynatech 1-3/4") that work well as far as interfacing properly with the "D" shape (i.e. they do not hang down and block the top of the "D").
The problem I am having is that because these headers are completely oval, they hang DOWN too far from the flange surface. Long story short, when the headers are bolted and torqued, a roughly 1/8" portion of the header primary is under-hanging the flange and is completely open and exposed. I can't do anything with the gasket itself to seal it up, and I feel that this is far too large of a gap to not worry about; it will cause a major exhaust leak, will cripple any notion of using a wide-band in the future, and may even spit fire.
My only idea is to have a qualified welder lay down a bead inside each of the primary tubes to cover up this exposed area, and then to machine the surfaces flat once more. Any other ideas/input would be greatly appreciated. I am also on a very limited time schedule.
Thanks a lot for the help everyone, cheers!
