View Full Version : 2010 camaro wheels on a 68
piznoot
08-01-2010, 11:00 AM
Will 2010 camaro wheels fit a 68 camaro?
What are the bolts patterns on each?
Can you buy hubs and axles to make them work?
Can other adaptations be made?
Vicinity
08-01-2010, 12:34 PM
5x4.75 for old camaros (5x120.7mm)
5x120 for new Camaros
The 18's may fit, I'd assume the same amount of work required to mount 4th gen wheels.
Apogee
08-02-2010, 08:35 AM
You'll need to run wheel adapters to make up for the different backspacing/offset requirements. You can convert the wheel patterns with the adapters, so that solves that issue. Hubs and axles could stay the same. If you do a search on adapting C5/C6 wheels, the principles are basically the same even if the numbers will vary slightly with the C5/C6 wheels being high-offset and the 2010 Camaro being medium-offset wheels.
Tobin
KORE3
novaderrik
08-02-2010, 07:39 PM
GMPP put a set of the base 18" wheels on the 55 Chevy that is on the cover of the '10 GMPP catalog. they had the backspacing changed to allow them to bolt on without adapters and to have the right "lip" for the car, but didn't say anything about the boltpattern. i think the bolt pattern is the same as the BMW wheels that some people have been known to run on GM cars without problems.
CamaroJoe
03-25-2012, 03:03 PM
That would look pretty cool if someone could get the new Camaro wheels to fit the old...
