View Full Version : ls engine to cowl hood?
sunkistcamaro
07-31-2010, 08:01 PM
Do you guys know if anything like this has been made.
I did a search but came up empty.
I was looking at getting the usual cone set up but I think it would be cooler to hook up to my cowl hood.
Bill
Zanie
07-31-2010, 08:19 PM
Andrew had the schwartz guys fab a hookup for his shaker scoop
https://www.pro-touring.com/forum/showthread.php?t=40904
mikey
07-31-2010, 08:22 PM
I'm thinking of doing the same thing. My thought is to install a FAST or similar injection system. That way it would basically look like a carb setup.
sunkistcamaro
07-31-2010, 08:29 PM
Im going to read Andrews thread to find a pic.
I wanted to keep the stock intake from the LS
alowerlevel
07-31-2010, 08:39 PM
Not quite the same, but the '97 Camaro SS's used the same idea
http://tinypic.com/view.php?pic=2ldyf6d&s=4
68sixspeed
08-01-2010, 01:02 PM
How about hooking it up to the rear, intake via the cowl vents by the wiper arms? (Intakes on ls1's can be turned around 180 degrees and bolted back on, they do that on GTM kit cars to get the air intake facing the rear)
Or to the grill-- (ProBell's car - functional ram air)
https://www.pro-touring.com/forum/vbpgimage.php?do=full&p=349
novaderrik
08-01-2010, 01:23 PM
i've always wondered why people don't just put a 180 degree bend off the throttle body that goes to an airbox mounted on top of the engine that uses a regular 14" round air cleaner that fits into the opening in the hood just like a stocker with a carb would do..
sunkistcamaro
08-01-2010, 04:55 PM
great ideas guys, thanks
coolwelder62
08-01-2010, 05:53 PM
Check out the blue 69 camaro in july 2010 hot rod mag.LS2 hooked to carbon fiber cowl hood.Will to post a photo.Or go to Lateral-g.net dec 2009 monthy feaure car.
sunkistcamaro
08-01-2010, 08:11 PM
Thank you, thats what Im looking for.
http://www.lateral-g.net/forums/showthread.php4?t=23975
sunkistcamaro
08-02-2010, 07:33 PM
Found Andrews pics.
https://www.pro-touring.com/forum/showthread.php?t=40904&page=16
Very NICE
