View Full Version : wheel sizes
Transporter70SS
07-25-2010, 08:59 AM
HI i have a 70 Chevelle that im trying to fit 18x10 lateral g wheels with 315/35/18 any thoughts if this would work good for the rear ??
JustinB
07-25-2010, 05:20 PM
A 315 is going to be tough. We have set up a ton of guys with a 305 on the back of a 68-72 A-Bodies but the backspace has to be spot on.
Transporter70SS
07-25-2010, 08:15 PM
I have done a lot of research for this car and on a set of 11" rims the offset would be 5 1/2 and with a 10 it would be 5" and the sumitomos 315 tires run a little small for their size thats why i was hoping it would work any info please let me know thanks
69cutlassrkt
07-26-2010, 04:27 AM
I have 315/35/17s on the back of my cutlass. They rub the quarter lip. I'm going to have the rear springs changed to raise it up a bit. Being a cutlass it may be a little different than your chevelle though. my wheels are 10.5" wide with 6.5" of backspacing.
Edit: only the right rear would rub. Maybe its cause only that wheel spins.
Transporter70SS
07-30-2010, 08:00 AM
what tires are you running on your rims ?
69cutlassrkt
08-01-2010, 11:27 AM
they are nitto nt555s. They measure 12" wide.
These pics are with the new springs
https://static1.pt-content.com/images/pt/2010/08/IMG00329201008011419-1.jpg
https://static1.pt-content.com/images/pt/2010/08/IMG00330201008011419-1.jpg
Nemesis RR
08-01-2010, 11:38 AM
did you think of shaving the lip of the wheel well a bit?
69cutlassrkt
08-01-2010, 11:40 AM
yeah I did. That probably would have fixed it. I like the new springs better though, a lot stiffer than the eibachs. The new ones are global west. Oh and having the rear raised more makes the tires look wider.
