View Full Version : weight: LS2 vs all-allum SBC? Fords?
mikedc
07-21-2010, 01:42 PM
What the title says.
I think World Products makes an aluminum SBC block, maybe there are others.
If you want a simple, carb'd, big-inch smallblock . . . which is lighter? Is there a big difference? Other issues?
How do the lightest-weight Ford V8s stack up to these?
sik68
07-21-2010, 01:56 PM
Here's an ongoing discussion of SBC weight vs LS weight:
https://www.pro-touring.com/forum/showthread.php?t=70591
Based on the info above, I would venture to guess that an all aluminum SBC would wind up a bit lighter than an LS, say 40-70lbs. But the LS is packaged a bit more compact, so you can probably set it in the chassis lower and get a lower CG.
From a weight savings standpoint, I think a Tremec TKO is lighter than a T56 by 30lbs or so....that helps, but you have 1 less gear to row.
Mkelcy
07-21-2010, 02:16 PM
I can easily see an all aluminum SBF (289 family) being lighter than an LSx, but not an all aluminum SBC. My guess is that they'd be pretty close.
