View Full Version : pics of fabbed trans tunnels?
Ripper
07-19-2010, 09:17 PM
I realised that I will have to make a new trans tunnel since the rear end came so high up in the body that the drive shaft won't fit.
Tried to search the forums for a little inspiration, but the project threads are just too long to g through...
Anyone have any pics of modified sheet metal trans tunnels?
parsonsj
07-19-2010, 09:20 PM
Here's some old stuff from II Much. All made from sheet metal, a $90 bead roller and lots of trial and error.
http://www.iimuchfabrication.com/Floor/
jp
tom_a
07-19-2010, 10:09 PM
https://static1.pt-content.com/images/pt/2010/07/1B6-1.jpg
https://static1.pt-content.com/images/pt/2008/06/1212-1.jpg
https://static1.pt-content.com/images/pt/2010/07/Roller003-1.jpg
dhutton
07-28-2010, 11:24 AM
Tom, how low is the ride height of your A body that you had to make those modifications? What year is your car?
Edit: Never mind, found your build thread. Nice work!
Don
PhillipM
07-28-2010, 03:28 PM
I had to do the same thing in our Olds. After I "C" notched the frame the driveline hit just about everywhere. Here are some pictures of it all.
https://static1.pt-content.com/images/pt/2010/07/IMGP3892Small-1.jpg
https://static1.pt-content.com/images/pt/2010/07/IMGP3883Small-1.jpg
https://static1.pt-content.com/images/pt/2010/07/IMGP3965Small-1.jpg
https://static1.pt-content.com/images/pt/2010/07/P1000346-1.jpg
https://static1.pt-content.com/images/pt/2010/07/IMG_0931Small-1.jpg
https://static1.pt-content.com/images/pt/2009/05/DSC01301Small-1.jpg
Also, here is one that I did for a 70 El Camino..
https://static1.pt-content.com/images/pt/2010/05/IMG_0168Medium-1.jpg
https://static1.pt-content.com/images/pt/2010/05/IMG_0171Medium-1.jpg
https://static1.pt-content.com/images/pt/2010/05/IMG_0182Medium-1.jpg
I used a slip roll and bead roll from Woodward Fab.
rjsjea
07-28-2010, 08:37 PM
The tunnel was fabbed all the way to the rear housing.
Ripper
08-05-2010, 06:05 AM
thanks for all pictures and ideas!
It turned out that the roller which I could use didn't roll with small enough radius, so I had to bend the sheet metal instead.
And I also realised that it's probably a better idea to fab the tunnel when the drive train is installed (which means that the body must come down from the rotisserie first).
Here's some pics: https://www.pro-touring.com/forum/showthread.php?t=67239&page=2
