View Full Version : IROC box swap questions
CarQz17
07-19-2010, 11:32 AM
A few Questions...
Will this box work on my 69 firebird? I have ordered the adapter kit from Lee MFG. What pitman arm do I need? The only one I can find works on 67-68 but no 69.
Also, I am trying to get the box from a local auto parts store but they can't seem to determine whether or not it came from a normal or an IROC camaro. Can I just determine that it is the IROC box if it has 2.5 turns lock to lock? That is all the information they can give me.
Thanks!
importkiller69ss
07-19-2010, 11:36 AM
i work at napa gimme a min and ill look it up bc i got mine from here and yes im almost 100% it will work on your bird and i used my stock pitman arm all i had to swap was the fitting adadpters and the rag joint.
importkiller69ss
07-19-2010, 11:39 AM
my number is 88277101 list price is 150 i can get it for you for 95 if you lived close to me.
srh3trinity
07-19-2010, 12:54 PM
Are there any markings that would help me to identify one of these boxes. I am doing some swapping with a guy on some interior pieces and he is going to pull the steering box out of a third gen V8 car as part of the swap.
importkiller69ss
07-19-2010, 12:58 PM
short of measuring the input shaft and out put shaft idk... i dont think there are any real part numbers on it. but if it came off a third gen v8 car chances are it is the quick ratio the code i see in my comp at work comes up that the quick ratio boxes are the ones without soft ride suspension FE1 code
CarQz17
07-19-2010, 02:02 PM
If my stock pitman arm is worn out I will want to replace it to get rid of the slop in the steering. Anyone know where to get a good replacement for a 69 bird?
importkiller69ss
07-19-2010, 02:17 PM
napa and carquest carry moog there good suspension stuff thats what i run and thats the same stuff you will get if you order it from classi ind jegs summit ect
astross89
07-19-2010, 03:24 PM
amazon.com was the cheapest I found. this was the whole front end in moog and the iroc box. and those are shipped prices. hope that helps
1 A1 Cardone 276550 Power St... $117.12 1 $117.12
Item Subtotal: $117.12
Shipping and handling: $21.23
Super Saver Discount: $-21.23
Total: $117.12
Paid by Visa: $117.12
You have only been charged for the items sent in this shipment.
(Per our policy, you only pay for items when we ship them to you.)
The following items will ship separately, as soon as they're available:
Qty Item Price Not Yet Shipped
1 Moog K6099 Steering Idler Arm $51.87 1
1 Moog K6582 Pitman Arm $63.10 1
2 Moog ES681N Steering Center L $19.35 2
2 Moog ES381RL Steering Center $22.18 2
whitess
07-19-2010, 04:26 PM
What I did when I was looking for a quick ratio box was take a pair of vise-grips and a rag with me (keeps the splines from getting damaged). Clamp the vise-grips over the rag and turn the shaft to full lock in one direction and then turn it to full lock the other way. Count the numbers of turns. The only thing this will tell you is if it's a quick ratio box or not. Also it'll have a elongated / squarish top cover w/4bolts and round outer edges. The boxes from the factory have "XH" stamped on them. AC Delco shows a listing for the 87-92 IROC's and Z28's that's 2-2.5 turns, PN 36-0516561. It doesn't specify whether it's for the ones w/16" wheels or for all. The one for the GBody's is 36-0516530 if you're interested, that one's about 3-3.5 turns.
Hope that helps some.
Larry.
cudaman
What pump and hoses are you using? When I did this swap I had to swage in the Lee adapter in order to get the proper flare for my hoses. No big deal at all, just something you won't want to overlook.
I reused my stock 69 camaro pitman arm. I just swapped in the Lee rag joint and flare adapters and was off and running.
I just asked for a steering box for an 87 IROC and no follow-up questions were asked. You cannot be disappointed with the swap. It makes that much difference.
Now, if I could only get the same steering feel in my 69 corvette....
cudaman
07-19-2010, 04:30 PM
If that's $117 for an IROC box, that's a great deal. I paid about $160, I think, four years ago. Any other mod I made to my car never came close to the steering swap in terms of bang for the buck.
astross89
07-19-2010, 04:32 PM
also try.
http://69camaro.nextmill.net/steering.html
astross89
07-19-2010, 04:33 PM
it is, 117 shipped and no core charge
importkiller69ss
07-20-2010, 09:47 AM
well if anyone is in louisiana i can sell them for that at my store and i just made some new lines out of hydrolic hose and fittings
srh3trinity
07-20-2010, 06:58 PM
I was at Advance Auto Parts tonight and the price was around 115 with a core. It was actually cheaper than the standard box. In their computer it specified 2.5 lock to lock, the other is 3.5 lock to lock I think.
cudaman
07-21-2010, 04:48 AM
The 2.5 is the IROC box.
zman1969
07-21-2010, 05:07 AM
check out this link:
http://www.camaros.net/forums/showthread.php?t=103139&highlight=iroc+swap
Great info on that thread
68Formula
07-21-2010, 05:46 AM
I had a heck of a time getting the pitman arm off my IROC box.
Would it be easier to remove the pitman arm off the original the box is still mounted on the car?
CarQz17
07-21-2010, 07:42 AM
I guess I still don't understand the pitman arm issue. If I buy a new pitman arm, does it need to be for a 69 firebird or the year specific part for the IROC camaro??
406 Q-ship
07-21-2010, 08:04 AM
Always use the pitman for the car it is going on. The pitman for the third gen would not even come close to fitting, early F-body is a rear steer while all the rest of the F-bodies are front steer.
CarQz17
07-22-2010, 08:13 AM
Cool, thanks!
srh3trinity
07-22-2010, 11:13 AM
For sure, I might not have been clear that the 2.5 lock to lock IROC box was actually cheaper than the stock box which is 3.5 lock to lock.
