View Full Version : Power steering blowing out fluid
Bowstring
07-18-2010, 03:06 PM
I ran my first track day this weekend. After everything got warmed up my power steering pump would blow out a little fluid any time I got near 6000 rpm. It is a late model GM pump also running a hydroboost. I have a small cooler in line. What is causing this and how do I fix it? A little fluid on the headers makes a big smoke cloud.
LowBuckX
07-18-2010, 03:24 PM
What tank are you useing.. Remote? brand? Baffled? Im thinking it is foaming the fluid because of poor baffling.
Bowstring
07-18-2010, 03:57 PM
The tank is mounted on the pump.
CarlC
07-18-2010, 09:01 PM
When you say late late model pump, do you mean TC, CB, P, ???? All are still in use today.
Bowstring
07-19-2010, 08:41 AM
Uhhhh, I guess I don't know. It is the same one that is on my 99 5.3 Silverado.
CarlC
07-19-2010, 09:01 AM
So it's a cast-iron pump, round, with a pressed steel reservoir. Similar to what was used originally. That's a P-pump.
Try a search on dry P-pump. Something should show up.
