View Full Version : roof weak in the middle
Footjoy
07-17-2010, 07:35 PM
I have a 70 Nova originally vinyl roof car. There is no rust but as I am stripping the paint I noticed the roof is weak and in some spots when you touch it the roof sinks about 3/4 of an inch. Comes back to the natural shape. What can I do to stiffen this section up.
fj
paul67
07-18-2010, 09:48 AM
remove headlining and see if any roof supports are missing.Put some sound deadening mat up there or some fibre glass strips with some foam glued in first about 2-3" wide every 18" or so across the underside then overlay with deadening 1 or the other should do.
Footjoy
07-21-2010, 06:58 PM
Thank you
fj
jocko124
07-21-2010, 07:10 PM
where can I get fiberglass strips?
paul67
07-22-2010, 06:36 AM
What you need is fibreglass mating cut into strips ,and then with resin and hardener mix brush it onto the over glued foam ,roof sorry for being not to detailed,you should be able to see using fiber glass on youtube.
200horse
07-22-2010, 06:38 AM
Before you do anything make sure that the material(glue/foam type material) between the roof and supportd are not missing or loose
Hammered
07-22-2010, 10:40 AM
That stuff is called anti-flutter foam. The major brands are Fusor and Duramix and you can get it at any autobody store or on-line.
