View Full Version : ls1 69 camaro
nzhotrod
07-14-2010, 01:08 PM
hi ya all
looking to replace my 307 with ls1 and auto, anybody know what I need to do the job, I have a fair idea, but want all the info before i start. I have motor, trans, loom,cpu, starter,powersteer pump...
Do i need to get made up power steer lines or can i buy them already made.
looking to buy efi fuel tank and headers, crossmembers.
any help what be great..
thanks
Nessumsar
07-14-2010, 01:11 PM
Welcome to the forum!
I would do a search of the forum, this has been discussed many times in great detail. I would start here: https://www.pro-touring.com/forum/showthread.php?t=14102
nzhotrod
07-14-2010, 01:24 PM
thanks Jon
Andrew McBride
07-14-2010, 02:28 PM
thanks
Fuel Tank: http://musclerodzstore.com/index.asp?PageAction=VIEWPROD&ProdID=616
Headers: check out dynatech $400 or check out Hooker headers for LS1, they both are fairly inexpensive. jegs.com
crossmember: BRP http://www.brphotrods.com/
If you aren't budgeting then there are plenty of other choices.
PhillipM
07-14-2010, 03:55 PM
welcome to the forum!
x3..
724tim
07-15-2010, 04:33 PM
I think this is the same tank for less.
http://www.thepartsplaceinc.com/ocatalog/part.asp?VID=3&YearList=1969
tazinhawaii
07-18-2010, 06:32 AM
It's not too complicated if you get the right parts up front. And if you have some LSx experience would probably help too. Check the link in my sig to pic's of my conversion. (personally I will never recommend BRP to anyone again. But there's a long story behind that). Anny specific questions please ask, but there are some useful links here.
Derrick
69importkilla
07-18-2010, 03:38 PM
What kind of driveline are you looking for? Manual or automatic?
I also looked at some of the links and found nothing about the power steering lines, something I'd like to know myself.
Dont hesitate to ask questions that's what the forum is for. Currently I'm working on my 69 with an LQ4 and a t-56 and I've gone thru some battles of my own, so ask away!
tazinhawaii
07-20-2010, 03:46 AM
I made the power steering lines using braided steel hose and some steel ends. It did take some work to get a fitting that would fit in the back of the power steering pump because of the bend it needs to take at the back of the pump. But that wasn't the most difficult part of my swap.
Derrick
67 ls1 vert
08-04-2010, 08:03 PM
:wf::screwy::getout:
67 ls1 vert
08-04-2010, 08:04 PM
I guess you deleted it.
69importkilla
08-05-2010, 01:36 PM
what the????
67 ls1 vert
08-05-2010, 08:48 PM
69importkilla... the guy before my post had posted a spam link and I made a commit about it the same time the moderator deleted it.
