View Full Version : vintage air will not turn off
platniumta
07-13-2010, 02:57 PM
I installed a gen4 vintage air kit in my 69 camaro and all was working fine. While driving it with the blower switch turned off it started to blow air from the vents. Started to check everything out and all looks fine. Kept trying to recalibrate the system and it seems to be doing the steps properly but it still will not work. It just blows air at a certain speed and out the vents but will not change speed or levels no matter where you position the switches. Its almost like it is stuck on a default setting. Any ideas???
KUL FIR CHICK N
07-14-2010, 05:39 AM
Please call Vintage Air - 800-862-6658. Mark can help you troubleshoot the problem. You could have a loose or damaged wire in the control panel harness, damaged pin in one of the ECU connectors, or a problem with the ECU itself. You can do more harm than good by probing around with a test light, so it's best to call first and have Mark walk you through it. You can also PM me and I'll help you out if you are unable to call during business hours.
Ryan
