View Full Version : In line pressure gauges
Skip Fix
07-13-2010, 09:44 AM
OK guys who has gauges you can add in line with calipers etc still hooked up? Like maybe 3/16 or 1/4" flair on either side? Maybe right off the master.
Apogee
07-13-2010, 01:41 PM
Like this Longacre (http://www.longacreracing.com/catalog/item.asp?id=774&catid=18) kit or Rebco (http://www.summitracing.com/parts/REB-120-4010/) unit? After checking, it looks like Summit carries the Longacre gauge cluster as well. These look like most of the gauges that I've seen for brake pressures, they come in pairs for front and rear systems and are intended for dash/in-cab mounting since that's where you can best monitor your brakes while in use. Plumbing-wise, they should have tee fittings with bleeders on the back to make things as simple as possible.
Otherwise, you could always mount a gauge to a tee fitting anywhere you wanted one really.
Tobin
KORE3
Skip Fix
07-13-2010, 02:33 PM
Thanks for the links Tobin!
That I think could help chase down brake system issues. Nicely priced also.
Apogee
07-13-2010, 07:28 PM
De nada. Let us know which way you choose to go and how it works out for you.
