View Full Version : Flush mounted glass what seal are you using ?
cluxford
07-12-2010, 04:36 PM
As the title suggests curious to see what brands those who have flush mount front and rear screens are using.
I have welded a bead inside the frames and will seal with sealant / glue to the frame, but then need to run the rubber seal on the outside to tidy it up, can anyone share what / where they got a rubber seal to fit
Thanks in advance
hj454
07-13-2010, 05:21 PM
sikaflex urethane, i use it for heaps of stuff there is a specific glass type they make also which i have used to fit flush glass aswell
hope this helps ...ash
Happyfunballs
07-14-2010, 04:39 AM
The rubber strip around my third gen camaro is pretty small. This (http://www.racepages.com/products/?Ntt=Chevrolet+Camaro+Windshield+Molding&N=4294963354) was the only link I could find, but it doesn't show an end view. I believe it gets "pushed" on the glass before installation.
elitecustombody
07-14-2010, 05:25 AM
All moldings should be installed on the glass before installation,most moldings have adhesive strip inside the channel that help to keep the molding in place. Safelite or Service Auto Glass carries all the supplies you need ,there should be a distributor in your area, I buy all my glass supplies from them
rrunner68
07-14-2010, 06:31 PM
So you guys get rid of the chrome trim around the windshield and make them more modern looking?
wim firebird
07-14-2010, 07:55 PM
https://www.equalizerfusion.com/ProductDetails.aspx?QString=Rnv7jzlYfxksHTu1OyyAQG VILhe6GhW0xCbj7V6m7vXclun+czlMs3NXrpYXwzhl
