View Full Version : Door Lock Install Kits
Modo Innovations
07-11-2010, 07:46 AM
Modo Innovations has developed a new kit for installing aftermarket door locks in the 67-69 Camaro/Firebirds.
Why an install kit?
Normally, aftermarket actuators include rods that must be bent by the installer and clamps to attach these rods to the lock plunger rods. The first issue is the clamps, they made of aluminum or some sort of pot metal and not very thick so it is easy to strip out the threads when tightening the set screws to attach the rods. Over time the clamps can become loose and cause your power door locks not to operate correctly or stop operating altogether. If the rods are not bent or attached in the right place they can affect the way the plunger feels, making it hard to lock or unlock by hand. Mounting the actuators can be a headache as well. Will they clear the door panel once installed, will they be out of the way of moving widow mechanisms and will I be able to put both screws in to the door or will I have to use the strap?
Included in each kit are powder coated steel brackets, fixture formed 304 stainless steel rods, rod clips, hardware, detailed instructions and drill templates. One kit is available for the 67 Camaro/Firebird and one kit for the 68-69 Camaro/Firebird and 69-72 Nova.
The drill templates locate the mounting hardware for the brackets. The mounting hardware is hidden behind the door panels. The brackets are manufactured so that they place the actuator out of the way of all the internal moving window mechanisms. The brackets also place the actuator in the proper alignment with the latch. The kit utilizes the unused hole in the door latch as the hook up point for the supplied fixture formed actuator rods. One end of the rod is manufactured to fit into the actuator and the other for the rod clip. (there is a driver’s and a passenger’s side rod and clip) The rod clips snap into this unused hole, then the rod into the clip. With a ¼ twist of the clip, it snaps over the rod to secure it into place
The price for the kit is $69 + $14 shipping
To order call 940-391-9002
The kits are the same parts only the drill templates are different.
MI 900 fits 67 Camaro/Firebird
MI 910 fits 68-69 Camaro/Firebird and 69-72 Nova
https://static1.pt-content.com/images/pt/2010/07/MI900-1.jpg
68 Driver's side installed
https://static1.pt-content.com/images/pt/2010/07/68MI910-1.jpg
69 Driver's side installed
*Disclaimer: "No useable doors were harmed in this photo"
https://static1.pt-content.com/images/pt/2010/07/dl011-1.jpg
Rod
07-11-2010, 02:07 PM
very nice kit
Modo Innovations
07-11-2010, 02:57 PM
very nice kit
Thanks, I have been working on this for some time. I even made a custom set of brake dies for the bends. I tested the bracket with and without the gussets and the built in gusset makes the bracket super strong.
slownova73
07-11-2010, 08:38 PM
they will fit 68-74 nova's too right?
Modo Innovations
07-12-2010, 06:04 AM
I don't know why they wouldn't. I would have to get my hands on a junk door to make sure they would. The templates would probably have to be re-worked.
parsonsj
07-12-2010, 06:15 AM
I've used this kit, and was very impressed. It made a disagreeable fabrication job into a simple hour's work.
Highly recommended.
jp
HotRod47
07-12-2010, 06:21 AM
I don't have a Camaro, but that looks like a nice kit at a reasonable price! Is this something you are now going to branch out and make for other model vehicles?
Smock67
07-12-2010, 08:56 AM
Ok so dumb question of the day... This kit is to be used in conjunction with an aftermarket power door look kit correct?
parsonsj
07-12-2010, 08:58 AM
In my case, I used it with an Electric Life (aftermarket) door lock kit.
Smock67
07-12-2010, 09:00 AM
Thanks John I just wanted to be sure. Yet another thing to add to my ever expanding list of things to do.
Modo Innovations
07-12-2010, 09:33 AM
I wanted to release this with a new keyless entry system. My supplier had some delays for the keyless entry, the new release date for the keyless entry will be later this month.
This kit will work with any keyless entry system that uses MES actuators. I have a dwg. that I made that I will put up later for those who don't have the MES actuators and want to use this kit. The dwg. shows the dimensions of the mounting holes and the length of travel for the actuator.
Modo Innovations
07-12-2010, 09:34 AM
Highly recommended.
jp
Thanks John.
Modo Innovations
07-12-2010, 09:36 AM
Yes, I used junk doors because I wanted to cut into them to make sure everything would clear and have a clear view of the hook up.
We will see what is desired and go from there.
Thanks.
dipren443
07-12-2010, 10:52 AM
2nd Gen Camaro next?!?! :)
Modo Innovations
07-12-2010, 01:54 PM
This one is the clear winner for next on the list as for now.
Here is the DWG I spoke of in an earlier post, for those who don't have the MES actuators. These are the measurements that are key in making other actuators work for this install kit.
https://static1.pt-content.com/images/pt/2010/07/DOORLOCKACTUATORDWG-1.jpg
dipren443
07-12-2010, 02:13 PM
Consider one set sold already!!!
zbugger
07-13-2010, 09:45 AM
Count me in on a 2nd gen kit. I just have to check my actuaries to make sure the measurements are right.
Modo Innovations
07-14-2010, 03:25 AM
These are now available on our website, click the link below.
Power door lock install kits (http://www.modoinnovations.com/id22.html)
FULMNTE
07-14-2010, 08:09 AM
If you plan to make one for GM-A Bodies, count me in for a set. Not happy with the current set-up...
John McIntire
07-14-2010, 09:39 AM
same here on the A bodies!
Modo Innovations
08-03-2010, 12:45 PM
I got this in an email from a customer today about this new product and wanted to share it.
"I installed the locks in the door using your brackets, and I've got to say that was the easiest thing I have done on my car yet. I couldn't be happier with them."
Mark
Thanks again for all who have purchased our products.
Stan W
08-03-2010, 03:06 PM
X2
I just got mine and installed it.
This is a top quality product.
You can tell right away that there is a lot of attention paid to detail.
Turbo67camaro
08-03-2010, 09:53 PM
Ordered mine today, and for a little extra $ Shannon hooked me up with the correct actuators (and a few other related things I needed).
Looking forward to getting this installed.
Thanks!
Modo Innovations
08-04-2010, 03:31 AM
X2
Thank Stan, I'm glad to hear you like the product and thanks for your business.
Thanks!
Good to talk to you Mike and thanks for your business. I hear alot of good things about the ISIS system.
John McIntire
08-04-2010, 01:12 PM
A bodies!! You have to do the A bodies next!! Start with the 70-72 Chevelles! Mine are already shaved, just seed a slick way to mount the actuators!
DarkoNova
08-04-2010, 05:54 PM
Will this work for 68-74 Novas? :fingersx:
Matt
Modo Innovations
08-05-2010, 11:35 AM
I will have to get doors for both of these to make sure that everything will work and do revisions if need be.
nicks67camaro
08-05-2010, 12:18 PM
Just went on your website and added to my "to do" list. Nice stuff.
Modo Innovations
08-06-2010, 04:35 PM
Sounds good. Thanks for adding us to your list.
79_EFI_Z
08-07-2010, 02:16 PM
I added this to my 'to do ' list as well. Hopefully by the time I get to it on my list, second gen brackets will be available?
69bigblock
08-17-2010, 11:16 AM
Does this kit still retain the door lock knob or is it deleted?
Modo Innovations
08-17-2010, 02:15 PM
With this kit you hook the supplied actuator rod to the opposite side of the latch. This leaves the door lock knob and factory rod untouched for this install. By using this install kit you can delete the door lock knob altogether if you want to and still have electric door locks.
Turbo67camaro
08-27-2010, 10:51 PM
I installed mine yesterday. The install was easy. A quality product with clear instructions. A nice time saver.
Modo Innovations
08-28-2010, 06:22 AM
Thanks Mike.
dipren443
09-13-2010, 10:17 AM
Thanks Mike.
Any updates on the 2nd gen pieces?
Modo Innovations
09-13-2010, 01:36 PM
I have been very busy and haven't had time to track down any doors. I have had a chance to do some research though. It seems GM changed part numbers on the latches some were in the mid 70's. What was the reason for the change? I don't know for sure, but I have seen some differences in the point where I plan on attaching the rod. I don't know at this point if it makes a difference or not. This is were the doors/latches will be needed to be checked and verified.
Thanks for keeping me in line and focused.
Shannon
absintheisfun
09-13-2010, 03:37 PM
If you are close to Denton, TX there is a junk yard called CTC Auto Ranch that may have some old beat up doors. If you let them, they will walk all over you with price. I can usually walk out of there at half of their original asking price.
John McIntire
09-13-2010, 04:08 PM
Don't forget us 70-72 A-bodies Shannon!!!
Modo Innovations
09-13-2010, 05:48 PM
I know the place well. I talked to them about several donor parts and have even bought some from them. They do have alot of cars there. They are a little on the pricey side, but if you need it, you need it.
Modo Innovations
09-13-2010, 05:49 PM
On the list to do as well.
Modo Innovations
11-11-2010, 06:36 PM
Update:
I am in the process of building the 2nd gen Camaro kits. These kits will fit 1970-81 Camaros. They should be ready to ship in a few weeks.
John McIntire
11-12-2010, 04:04 AM
A bodies damn it!
Great product you have to simplify this process!
malibumike
01-12-2011, 02:29 PM
been looking for a kit to make my life easier on converting from manual to automatic door locks. need to see a kit for a bodies. consider another one sold and you get them made.
1969CamaroRS
01-12-2011, 04:21 PM
Got a question, does your electric trunk lock work with your key-less entry fobs? I.e. can you pop the trunk open with the key fob?
Thanks!
HOSTILETAKEOVER
01-12-2011, 05:49 PM
Santa brought me the kit for christmas ;)
The templates are worth 9/10ths of the price but the entire kit is exceptional fit and finish. For once bolt in actually means bolt in!!
Modo Innovations
01-12-2011, 06:40 PM
Thanks!
Yes, you can operate the trunk latch with the key fob. You will need another relay to do this and the relay comes with detailed wiring instructions so it makes the wiring a breeze.
Modo Innovations
01-12-2011, 06:44 PM
Thank you for the compliments on the kit. I feel that the templates are just as important as the hardware in the kit.
John McIntire
01-13-2011, 10:35 AM
Shannon, you still working on an A body door kit?
Modo Innovations
01-13-2011, 05:12 PM
The 68, 69 and 70-72 doors are all different. I am still researching all the differences in these years. The 64-67, I haven't even looked at yet.
John McIntire
01-13-2011, 06:47 PM
Well start with the 70-72's please!!! Haha!!
Modo Innovations
01-29-2011, 02:55 PM
Just an update for everyone. We now offer the actuators by themselves if you want to purchase them with these install kits. I have had several requests from those who are using the ISIS system.
The actuators are $18 each.
duckmanjbr
03-09-2011, 10:21 AM
Nice clean kit! :)
69cutlassrkt
03-27-2011, 10:01 AM
I too would buy one or a 69 GM A-body. I get tired of reaching over and unlocking the passenger side door. Well just unlocking the doors manually in general.
