View Full Version : ??? About Wilwood Rear parking Brake Kits
Rallye455
07-08-2010, 02:13 PM
I have the Wilwood 140-7139 rear brake kit for my 9" Ford with Moser Axles. The axles have bolt in studs and the heads are hitting the Wilwood parking brake assembly. I assume the kit was designed for axles with press in studs. What has anyone done to correct this? I would hate to have to grind down the heads of the studs.
sebtarta
07-08-2010, 04:04 PM
Did you call Wilwood?
Rallye455
07-08-2010, 04:36 PM
Yeah. left a message. Was hoping someone else had an easy solution. Right now it looks as though I'll have to grind them down or remove the studs and drill the axles for a press in stud.
Payton King
07-08-2010, 07:52 PM
they will clear if the have a allen type head you will need to grind on them. Moser has the the hex bolts just replace. been there done that
Rallye455
07-09-2010, 02:42 AM
I have the hex bolts they do not clear.
sebtarta
07-09-2010, 06:06 AM
Call Moser and see if they have different studs for that application.
Rallye455
07-23-2010, 06:24 PM
I ended up cutting the heads down. Fits fine now.
