View Full Version : Need some thoughts on Hellwig rear Pro-Tour sway bar
staged67gspwr
07-04-2010, 04:09 PM
Need some input on Hellwig`s new rear pro-tour bar for gm A-Bodies.
$Mike70Z-28
07-05-2010, 06:47 AM
yo lalin try this http://www.chevelles.com/forums/showthread.php?t=299254
Dave@Hellwig
07-08-2010, 07:19 AM
Our Pro-Touring rear sway bar relocates the sway bar from the lower control arms to the rear axle, which improves handling by allowing the suspension to freely articulate. The sway bar is made from 1-1/8” diameter alloy tubing to reduce weight and incorporates 3 holes to adjust roll stiffness so that the suspension can be tuned to match your suspension upgrades and/or track conditions. The sway bar is connected to the frame with adjustable end links that accommodate stock or lowered ride heights and incorporate hourglass bushings to allow 5X more articulation than a straight cut bushing. The end links are connected to the frame with our integral clevis/tailpipe hanger (pat pending) that allows factory exhaust hangers to be used with the kit. The kit includes polyurethane bushings and all hardware required for installation.
This kit has been very well received in the marketplace and I can personally say it works as I did the development on my own 64 and 68 Chevelles. I had our factory style 1" bar installed previous to developing this kit and the ride and handling the new bar offers is a huge improvement over the factory style bar. When you take out the bind in the lower control arms, the vehicle is more compliant and ride quality and handling both improve.
IrvJr
07-08-2010, 10:24 AM
Is there one available for G Bodies? Are they on your site yet?
IrvJr
07-08-2010, 10:31 AM
I see the old style for the rear but not the newer.
Randy67
07-08-2010, 10:54 AM
SC and C does have a bar like this for the G-body, at the bottom of this page, if Hellwig doesn't have one:
http://www.scandc.com/spohnarms.htm
John Wright
07-08-2010, 11:19 AM
SC&C also carries the Hellwig bars:
http://www.scandc.com/hellwigswaybars.htm
Dave@Hellwig
07-09-2010, 06:52 AM
G-body Pro-touring bar is coming. We are finishing up test fits and tooling.
staged67gspwr
07-09-2010, 06:53 AM
Dave can you email me a instructions sheet for the 64-67 bar?i`d like to see how it mounts and if any drilling required.
Dave@Hellwig
Part numbers for the Pro-Touring Bars are as follows
55864 64-67 GM A-Body
55868 68-72 GM A-Body
55809 78-87 GM G-Body (available August 2010)
LV42DAY
07-09-2010, 08:26 AM
am i to understand that this kit completely eliminates the front sway bar to be used with only this one rear?
John Wright
07-09-2010, 08:36 AM
No this rear bar is used to balance the car, and being that it is adjustable, it eliminates having to have several different rear bars with various rates to find the balance.
Dave@Hellwig
07-09-2010, 10:18 AM
If you have tall spindles or tall ball joints like the SC&C stage 2 package, we reccomend our tubular 1-1/4" sway bar for the front. If you have stock geometry, our tubular 1-5/16" front bar is best.
alowerlevel
07-09-2010, 11:20 AM
How about a 73-77 A-body one? :fingersx:
Dave@Hellwig
07-09-2010, 03:16 PM
73-77 is coming. No ETA yet.
alowerlevel
07-09-2010, 07:25 PM
Sweet :cheers:
Im glad to see more and more companys finally making parts for the 73-77 cars.
Yelcamino
07-10-2010, 02:57 AM
Summit has them too... (http://www.summitracing.com/parts/HEL-55864/)
