    Results 1 to 4 of 4
      Vancouver BC
      Great rear swaybar option for 2nd gen Fbodys (may work for 1st gens too?)
      Hey guys,
      I found a great way to do a rear swaybar on 2nd gen Fbodys. It gets rid of those flimsy brackets and makes for a very simple,clean and effective setup. Take a 3rd/4th gen rear swaybar (mounts to the axle tube with U-bolts) and point the ends of it towards the front of the car. It lines up almost perfect with the frame rails and you just need to fab up a simple/short bracket for the end links to go into. The pros are: its stiffer, more effective, simpler, better looking and lowers the weight (very slightly). The cons are you have added the weight of the swaybar to the unsprung weight.
      I think its well worth it and wish I had seen it before I got rid of my camaro. Little upset that I didn't figure it out for myself considering how many times I have held a 4th gen swaybar in my hands.
      Jun 2002
      Benicia, CA
      Kinda what I did...
      I used the u-bolt idea too, but I subsituted rearend u-bolts for the swaybar ones, tightened them in the desired position, then tack-welded the custom bracket to the rearend tube. If I ever need to move it around I will just grind the tackwelds and adjust as needed. The reason I figured this out was because I had a 3rd Gen rearend and kept the swaybar parts after trading it to Vince. I didn't like the thin brackets and u-bolts, so came up with my own beefy stuff.
      Jeff
      1971 RS Camaro: PAINKILLER
      little falls minnesota
      samting
      did the same,only on a 93 silverado. takes just the right amount of push out to increase speed on some corners to work by 10-15 mph.
      doug
      Warminster, PA
      this is a great idea, ill have to remember this when im doin my suspension...
      1979 Trans Am - In the big junkyard in the sky
      1980 Turbo Trans Am - In the big junkyard in the sky
      A journey of a thousand miles begins with a single BURNOUT!
