Results 1 to 17 of 17
05-08-2005 #1
New to Pro-Touring
- Join Date
- Aug 2004
- Posts
- 27
hotchkis springs 1 1/2 drop??? bull****
i bought the 1 1/2 inch drop springs from hotchkis and got a whopping 1/4 inch drop! i'm pissed ive got the entire front end back together and now i've got to take them back out and cut them, could have done that with the stock springs.
anyone have any idea how i can get 1 1/2 to 2 inches more off my front end. how much do i need to cut off the springs?? any help appreceated.
05-08-2005 #2
Pro-Touring Veteran
- Join Date
- Aug 2004
- Location
- NY
- Posts
- 1,070
Easy give it a couple of months they will settle about an inch.
05-08-2005 #3
New to Pro-Touring
- Join Date
- Aug 2004
- Posts
- 27
i don't think they will, the springs were put in the car about 4 months ago with the front end off, we then put the car on jackstands (which were directly under the a arms) now we are ready to put the fenders back on and i have a 2 inch gap between my tire and the fender. i had the rear multi leafs de arched 2 inches and they came out great just tucking the rear tires. i've went through this before with a mustang, i was told they would settle, i drove it for 8 months and it still sat like i had a load of dirt in the trunk.
05-08-2005 #4
05-08-2005 #5dennis68 GuestWere the springs you replaced brand new springs? You gotta remember that the drop is based off stock height, not your 35 year old sagged spring.
Coil spring specialties will custom wind whatever you want, tell them the height you want and what rate...about 135.00/pair.
05-08-2005 #6Is the front of the car all factory? Meaning do you have a fiberglass hood, alum. heads, battery in the trunk or have you made any other modification to lower the weight of the front of the car? If so the spring rate will be off and the front end will be very bouncy.
I cut a full coil from my Hotchkis springs, to compensate for all the weight I removed. I can assure you that the springs will not settle much, I've had mine for about 9 months.Mike
1975 Camaro
C5 Corvette
05-08-2005 #7
Pro-Touring Veteran
- Join Date
- Aug 2004
- Location
- NY
- Posts
- 1,070
Springs do settle with wear. Make sure they are seated in the pockets correctly. I also agree with Dennis as you have to measure from approx orig stock height which was pretty high. Hey if you want to go lower cut one coil out. Remember you aren't going to get air bag look with stock set up. Also do yourself a favor a turn wheel full lock both ways and then measure how much you can drop before hitting lip. Subtract at least 2-3"'s for compression when you hit a bump. Just curious as to what size tires you are running? Good luck.
05-08-2005 #8
