View Full Version : camaro door repair
greycamaro
06-26-2010, 06:39 PM
Does any one make a door repair for the lower front part of the door that rusts out. or will this need to be fabricated?
alex
toxicz28
06-26-2010, 06:51 PM
Fab your own, or buy repop or good door shells.
67 ls1 vert
06-26-2010, 07:04 PM
dont waste your time or money with the skinning, just use a cut off wheel and cut off the bad spot and use it as a template and weld the new piece back in. Piece of cake.
TA219
06-26-2010, 08:39 PM
I have skinned two and It isnt THAT bad, I would say that either way you are looking at using some body filler... but at least with a skin you know that you have a completely rust free door.
class67
06-26-2010, 10:26 PM
Agreed!...I re-skinned both my doors and it really is not bad, but a patch would work as well.
Jim Nilsen
06-27-2010, 05:42 AM
It can take just about as much time to do a patch as it does a new panel.
You decide if you want a patch that can haunt you later or a new panel that might not fit as well around the edges because your skill level wasn't up to it? it really is an easy job but that's just me.
make sure you line it up and tack it together on the car and not on a set of saw horses or a bench.
greycamaro
06-27-2010, 08:07 AM
looking at this more I believe I should explain that a skin was put on previous owner, but did not fix the rust on the door shell. do they make a patch pnl for the lower shell?
alex
dhutton
06-27-2010, 08:45 AM
No patch panels for the shell as far as I know. Either fab it, find a donor shell or buy a new shell.
greycamaro
06-27-2010, 09:09 AM
what are the cons on the repo door shells?
ProdigyCustoms
06-27-2010, 09:57 AM
For what year doors? There are lower section for 67 / 8 doors. 69s are just flat sheet
greycamaro
06-27-2010, 10:07 AM
1969 door. its on the front part of the shell. where the curve section is.
Jim Nilsen
06-28-2010, 05:50 AM
I once hammered and dollied a piece for the front lower curve area from 2 pieces of steel and welded them together to get the shape and then welded it on the inner panel. it's a lot of wrok but it can be done.
Good luck.
The best alternative is another door if you can find one reasonable.
