View Full Version : rear brake sticking?
a73formula
06-22-2010, 10:50 AM
Haven't had a chance to really get in and look yet but it sounds like my driver side rear brake is sticking. When I do a burnout only the passenger side is spinning. I have line lock and a 9" with a 31 spline locker and wilwood discs. When I drive around everything works fine. Just looking for Ideas before I start taking things apart.
thanks
silver69camaro
06-22-2010, 11:55 AM
Can you jack it up in the air and turn the wheel by hand?
a73formula
06-22-2010, 09:18 PM
yes and both wheels still turn at the same time that way. Thats as far as I've had time to check so far.
Apogee
06-23-2010, 05:52 AM
Just to clarify, the line lock is installed in the front circuit only, correct? It's possible that it has something to do with the brakes, but it's also possible that your brakes are fine and that you have a limited slip/locker issue. If you post up the type of traction device you're using, someone may be able to provide you with the proper testing procedure.
Tobin
KORE3
