lachowich
06-21-2010, 02:17 PM
I'm a long time lurker but I finally have my project at a point where I feel its fair to share it. I'll attach a few pictures, please disregard the terrible stripe put on it by the previous owner. Also, included my list of modifications made and planned. The car is a 1985 Monte Carlo SS Hardtop.
1985 MONTE CARLO SS
COMPLETED UNDERHOOD & DRIVETRAIN
-GM Performance Parts ZZ383 Crate motor 425 hp 475 ft/lbs torque
-March Performance Billet Aluminum Serpentine Pulley conversion with A/C
-Converted to Sanden A/C Compressor
-Two Piece Aluminum Chevrolet Valve Covers in satin black with red lettering
-Chevrolet Air cleaner in satin black with red lettering
-Edelbrock Performer RPM Manifold (Polished)
-Edelbrock 650 cfm carb
-Replaced fuel lines with stainless with A/N fittings (bare polished)
-Billet aluminum fuel filter & polished stainless hard line to the carb
-Billet aluminum throttle return spring setup
-Performance built 700-R4 trans with shift kit
-Hurst Roll Control
-140 amp Alternator with chrome housing
-Custom transmission cross member
-Custom sized driveshaft
-True dual exhaust
COMPLETED INTERIOR
-New seat foams on front bucket seats
-Fully reupholstered bucket seats and rear bench in Oxblood Maroon
-Replaced all interior speakers with high end Alpine
-Replaced head unit with Alpine CD changer
-Upholstered rear packing shelf
-New Upper door panels
-Replaced worn electric window & lock switches
-Replaced door pull straps & end caps
-New Carpet
COMPLETED SUSPENSION
-Replaced front lower A-Frames with Tubular Chrome-Moly (UMI)
-Replaced front upper A-Frames with Tubular Chrome-Moly with aluminum shafts (Speedway)
-Converted coilsprings to QA1 12 way Adjustable coil-over shocks (adjustable ride height)
-Billet steel tie-rod adjusters
-Rebuilt all steering components
-SSBC aluminum 2 piston brake calipers
-Stainless steel brake flex lines to front calipers
COMPLETED BODY
-Patched floor & wheel wells
-Replaced all seam sealer
-Painted floor, trunk & wheel well with POR-15
-Purchased rear passenger quarter panel (used)
-Purchased new front fascia
-Purchased new front hood emblem
PLANNED BODY MODIFICATIONS
-Shave Antenna & Replace with internal style above rear view mirror
-Shave All door locks & Handles, replace with 90lb actuators
-Shave Driprails
-Flush mount quarter windows
-Flush mount existing front windshield and rear window (if feasible)
-Replace side marker lights with flush mount style lenses with LEDs
-Shave License plate lamps and replace with lighted license plate bolts
-Fabricate panel behind rear license plate for flush mount gas cap
-Replace all incandescent lights with LED bulbs
-Smoke finish side marker & tail lights with black tinted clearcoat
-Fabricated front Inner Wheel wells attached with quarter turn fasteners
-Fabricated rear firewall behind back seat
-Stainless steel hood bumpers/adjusters
-Black powdercoat hood hinges / latches / etc
-Replace factory external vents on cowl with black aluminum mesh
-Replace door jamb vents with black aluminum mesh
-Shave factory door jamb wiring loom holes
-Replace factory door jamb wiring looms with stainless steel/billet looms
-Stainless steel door strikers
-Change rear license plate flip down to self-locking 91-96 Caprice style
-Replace Fisher Logos on scuff plates with SS logo
-Fabricate closeout panels to cover factory gaps between core support and body attached with quarter turn fasteners
-Move all wiper fluid resevoir and radiator overflow under fabricated closeout panels
-Fabricate smaller A/c / Heater Box
-Replace A/C & Heater firewall fittings with Billet Aluminum A/N fitting style panel
-Smooth firewall where possible
-Paint entire car in Chrylser Brilliant Black Chrystal Pearl
-Have all Monte Carlo SS decals on body replaced with Oxblood Maroon lettering painted on
PLANNED INTERIOR & ELECTRICAL MODIFICATIONS
-Upholster trunk
-Theater style dimming interior lighting and Accessory power retention (Dakota Digital)
-Military Spec electrical quick disconnects on firewall and rear firewall
-Sound deadener on door panels, trunk and interior floor and package shelf
PLANNED UNDERHOOD PERFORMANCE MODIFICATIONS
-Replace mechanical engine fan with high cfm electric
-High performance aluminum water pump
-Electric fuel pump
-MSD Distributor & Ignition box
-Road Race style oil pan
PLANNED SUSPENSION AND CHASSIS
-Adjustable outer tie-rods
-Complete boxing of frame & fill in unnecessary holes
-Fabricate driveshaft safety loop
-Add additional brace to front braces to triangulate
-Additional brace behind rear seat
-Additional tubular brace at rear of frame
-Polyurethane sway bar links & Mounts
-Polyurethane body mounts
-Helwig adjustable Pro-touring style rear sway bar
-UMI Performance adjustable rear upper and lower control arms with Roto-Joints
-UMI Performance rear frame braces
-QA1 adjustable ball-joints (upper & lower)
-Hydroboost brake booster
-Convert to rear disc brakes
-QA1 12 way adjustable rear coil-over shocks (adjustable ride height)
-Replace all brake lines with stainless steel
-Replace all A/C & Heater Lines with stainless steel with A/N fittings
-Replace 3.73 10 bolt posi Rear-end with 3.73 12 bolt posi
1985 MONTE CARLO SS
-Hurst Roll Control
-True dual exhaust
COMPLETED INTERIOR
-New Carpet
COMPLETED BODY
-Shave Driprails
-Upholster trunk
-Electric fuel pump
