    Results 1 to 10 of 10
      McKinney, TX
      Vintage Air issue
      This is an older issue for me but I might as well fix it. Last summer I installed a Vintage Air kit on my Mustang. It work for a few months and then the car sat for about 3 months. When I tried to use the A/C again it wouldn't work but when the compressor would cycle, the whole car vibrated and it made one hell of a racket. I havent tried it since so that I dont think I messed anything up. Any ideas?
      89 Mustang "Box Wine"
      Jul 2007
      Olathe, KS
      Have you put a set of gauges on it? If so, what are the hi and low side pressures?
      Given the fact that the compressor would vibrate I would put my first look into checking to insure the system wasn't over filled with either refrigerant or oil. When overfilled you'll get liquid sucked into the compressor, causing it to shutter.
      McKinney, TX
      Does that cause damage? Can I just vent some off?
      Phoenix
      Don't just vent some off (which you shouldn't do anyway) until you know what the pressures are like Rhino said. The compressor isn't just loose is it?
      Erik
      https://www.pro-touring.com/showthre...without-a-name
      Camaro LS2, T56, 12 bolt, C6 Z06 brakes, Rushforth Super Spokes, ATS Spindles
      2006 Chevy Trailblazer SS
      McKinney, TX
      I guess I meant would I need to totally evac the system or not. Everything is tight.
      Phoenix
      Don't have to totally evac the system no, you can just recover enough to bring it to the proper charge level.
      Erik
      McKinney, TX
      Can someone do me a favor and measure the resistance on their VA compressor? Mine is reading 0 ohms across the board and we believe it to be shorted. That would lead to the compressor being bad right?
      Sep 2004
      San Antonio, TX
      Please call VA for help. You should never try to adjust the charge without the proper equipment. It sounds like the system may be overcharged. You should always charge the system by weight and you need to have gauges on the system to troubleshoot. If you're overcharged, you need to evacuate completely and start over. This is a job for a shop with a charging station because they need to measure how much refrigerant and oil was pulled out. You have to add back any oil that comes out during recovery.
      Jan 2000
      Thousand Oaks California
      I agree on possibly over charged. I did the same thing to my truck.
      Larry Callahan
      McKinney, TX
      Well, we did some head scratching and seem to think that the dash switch possibly arced and is causing a high resistance. I bought myself a SPDT 30A relay to wire inline after the pressure switch to power the compressor.
