ledoux67
06-11-2010, 04:17 PM
I have went from prostreet to more of a pro-touring route in my 1967 camaro build. I am going to keep it a little of both but the more i read into pro-touring i start getting away from pro-street.
I have a 1967 camaro that was already set up for the 1/4 mile, full frame car, back half, and had a 383 SBC. When i bought the car i stripped it to nothing and started to rebuild. I took the SBC motor apart and found bent pushrods and a rounded off cam then i dug deeper and the bearings were shot. So now i got myself a 5.7 LS1 out of a 2003 Corvette and have a butt load of ideas but i am new to the LS motors.
I have been searching for the last month and doing research before i asked any questions so i did not get told to use the search button "LOL". I think i have read all the engine build installation threads etc. and then some more than once to make sure i did not ask stupid questions. I know the LS1tech.com site has alot of info but as i am offshore now and can not enter the site due because it blocks the site. The computers are pretty restricted out here so i have to make due with what i have.
Now that i have explained everything these are my questions if anyone wants to push me in the direction i need to go.
I am using my 241 casting heads and porting and installing 2.05 valves. The guy doing the port work is well known for excellent work so i feel confident that he will do a good job.
Question #1 I saw i can use the LS6 valve springs to get up to 570 lift, will these fit the 241 heads without any mods.
Question #2 If i go with a cam that has around the lift the springs will hold do i need to go with stronger pushrods.
Question #3 I am doing the carberated intake and LS ignition "I already have the Quick Fuel carb and Fuel cell etc." Can i port and polish the intake and port match the intake to the heads to Get extra HP? again i can not find much on the carberated LS motor builds.
Question #4 On the pulley system i will only be running the Alternator and the water pump. Is there a way i can run just that or will i have to make custom brackets?
Question #5 Is the truck coils better than the others as i read somewhere? If so i will be going to the junk yards when i get in from offshore. And if so what years do i need to look for.
Question #6 I know the cam sensor is on the top of the block, and the crank sensor is on the side of the block but what sensor is in the oil pan? I doubt i need it and can it be plugged.
Question #7 Where is the better place to run a manual oil pressure line at the top of the block or by the filter.
One more #8 I will be trying to squeeze out as much HP as i can out of this thing, will stock rod and main bolts be fine or do i need to go to ARP. The motor is on the stand now with the intake off and oil pan off. I am on a budget so if they should be fine i will not worry about it.
Any answers will help and as soon as i get in i will post this on LS1tech also.
