View Full Version : G-body LS1 Front Brake Bracket Drawing
somcamaross
06-08-2010, 10:06 AM
Anyone have a .DWG of the bracket that mounts to the spindle and holds the caliper abutment bracket?
Ive searched around and I remember seeing a dwg SOMEWHERE but cant find it now...
TIA
-Brandon
somcamaross
06-08-2010, 01:47 PM
Found it! *this is actually the f-body bracket, see next post*
http://www.lukeskaff.com/car/brakes/bracket.html
I actually took the .DWG file and dimensioned it.
Ill host it on PB and get it up here this afternoon if possible
somcamaross
06-08-2010, 07:43 PM
I just found out that all of the g-body guys that have LS1 Discs on the front are using a different bracket than above.
That one is supposed to fit a third gen f-body spindle(which I was under the assumption was the same as the G-body spindle.)
Now working on getting another .DWG for the G-body bracket
Pictures C/O FlyNBye Performance
F-body bracket (.DWG posted above)
https://static1.pt-content.com/images/pt/2010/06/C4LS1web-1.jpg
G-body bracket:
https://static1.pt-content.com/images/pt/2010/06/BGSLS1Bweb-1.jpg
somcamaross
06-16-2010, 12:35 PM
doesnt look like theres any interest in it, but I have the .dwg of the lower bracket if anyone needs it.
nonosv6
06-16-2010, 07:40 PM
I'm interested in it,what exactly is it that you have?just got my ls1 brakes yesterday n now I need to get the adapter brackets or make them. Thanks, Joel
somcamaross
06-17-2010, 01:02 PM
a .dwg Autocad file of the peice in the lower picture, Which is used to mate LS1 calipers to G-body spindles
Skip Fix
06-17-2010, 02:09 PM
FWIW Wlwood is coming out with a twin piston metric caliper that wil bolt to some of these cars.
makindue
07-01-2010, 10:05 PM
TIA
-Brandon
My friend has that dwg. I will ask him if he has that dwg in his garage. :D
nonosv6
08-14-2010, 08:43 AM
Any luck with the file?I need to make a templAte and do my car soon. Thanks , Joel
