View Full Version : Cleaning fuel injectors?
Samckitt
06-04-2010, 11:04 AM
Where do you guys have your fuel injectors checked/cleaned? I bought a set of 30# ones a while back & something is wrong with at least one of them. Need to have them checked.
Scot
Ollie8974
06-05-2010, 04:36 AM
Witch Hunter. But they are here in the Seattle area.
http://www.witchhunter.com/
Mike Norris
06-05-2010, 09:35 AM
Hey Scott, there is a place on Gasoline Alley but iI can not remember the name right now.
Samckitt
06-05-2010, 10:24 AM
This guy is in Speedway:
FUEL INJECTION DIVISION
1330 MAIN STREET
SPEEDWAY, INDIANA 46224
317-487-9460 Office
BBPanel
06-05-2010, 01:55 PM
I've wondered about this also - no easy way to do it in the home shop?
Mike Norris
06-06-2010, 11:04 AM
Same place Scott, they just moved from Gasoline Alley not too long ago.
Mike Norris
86Cutlass383SR
06-08-2010, 12:49 PM
Scot I did a search on this and found where a guy made his own setup. Basically used a 9v transistor battery to open the injector and used pressurized cleaner to clean them. Same guy also sold the little filter and o-rings to replace afterwards. Cost about $25. If I find it, I'll send the link.
Found it. http://fordfuelinjection.com/?p=82
and another http://www.pelicanparts.com/techarticles/944_fuel_injector_clean/944_fuel_injector_clean.htm
http://www.rowand.net/Shop/Tech/DIYFuelInjectorCleaning.htm
Here's the one that used the 9v battery http://specthismiata.com/2008/06/15/injector-cleaning-at-home/
This one has an attached YouTube video http://www.watkinsmotorsports.com/how_to_rebuild_a_fuel_injector.aspx
http://www.youtube.com/watch?v=VFJlTfHyrUk
Nathan
06-08-2010, 05:12 PM
Right on! thats the info I have been looking for:idea:
Fuelie Nova
06-08-2010, 06:29 PM
I have had great luck with the procedure in the first link. Done it several times and it works great.
I am going to try and build my on test stand to measure flow.
Tom
