View Full Version : 6.0 power?
progoat
06-03-2010, 04:48 PM
Hey guys< I'm just looking to see what type of power I could get out of a truck 6.0 short block? I would like to put about 400hp to the wheels through a t-56. Is this type of power easy to substain or would it take quite a bit of time and money?
progoat
06-03-2010, 04:50 PM
I should also add What type of heads and cam do you think it would take?trying to keep on a tight budget but just looking for opinions
hifi875
06-03-2010, 06:28 PM
l92 heads and a camshaft and youll be there easy. I had a 6.0/t56 in a 68 firebird w/patriot heads and .580 lift cam. it was a handfull
1badchevelle
06-03-2010, 09:41 PM
what he said
68topls
06-04-2010, 06:07 AM
400hp would be easy. And that would be using stock heads. A stock LQ4 makes 300hp. Stock lq9 (higher compression) makes 345hp. Intake, hotter cam, and bolt ons would put you well above the 400hp mark.
progoat
06-04-2010, 10:27 AM
I'm wanting 400HP at the wheels, I've read there easy to make power with with slight mods but I'm guessing i'll have to put out close to 500 at the crank to put 400 to the wheels?
Mkelcy
06-04-2010, 11:25 AM
Spend some time browsing over on www.LS1tech.com (http://www.LS1tech.com). The power levels you want, believe it or not, are routinely achieved.
progoat
06-04-2010, 12:21 PM
I knew that was going to pop up, I've been on there and can't make heads or tails of that site:hammer:
ProdigyCustoms
06-04-2010, 12:31 PM
L92 heads and a cam in the 228 range with springs, just shy of 600 lift will put 425HP to the tires.
http://www.youtube.com/watch?v=_wI8PNg0l9s
tooblue
06-04-2010, 01:05 PM
6.0 = LQ4, L92,l76, TR224 / 114, 4l60e 3k stall, Custom Tune, 408hp rwhp = on the motor,,.. Roger
progoat
06-04-2010, 03:16 PM
Ok thanks guys and thanks for the vid link Frank:twothumbs
MISLEAD NOTCH
06-10-2010, 11:28 AM
By anychance can those numbers be achieved with ported and polished 243 casting heads? what cam would be necesary to reach those hp numbers?
LSXZ28
06-17-2010, 02:53 AM
Yes, I had those numbers with a 6.0L, box stock 243 heads, and a 228/232 cam...
My personal recommendation for a cam for you would be the Torquer V.2 from Texas Speed: http://www.texas-speed.com/shop/item.asp?itemid=168&catid=44
Rhino
06-17-2010, 05:22 AM
Another vote for the V.2. I have it in an LQ4 I dropped in my Avalanche. I'm very pleased with it.
